StarTech.com Mini DisplayPort to DVI Active Adapter
Quicklinx: 7NZMWS00 Mfr#: MDP2DVIS
The MDP2DVIS Mini DisplayPort to DVI Active Adapter (single-link) lets you connect your Mini-DisplayPort video source to a DVI-D display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort capable monitor.
Unlike passive video adapters, this Mini DisplayPort to DVI adapter offers an active conversion for use with any Mini DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
Supporting resolutions up to 1920x1200, this compact device provides a simple solution for adapting PC or Mac Mini-DisplayPort output for DVI monitors, televisions or projectors.
The Mini DP to DVI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com Mini DisplayPort to DVI Adapter - 1080p - Single Link - Active - Mini DP (Thunderbolt) to DVI Monitor Adapter (MDP2DVIS) - DVI adapter - 20 cm
DVI adapter - dual link
HDCP compliant
Length
20 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
3-year warranty
DVI adapter
TMDS Links
Dual link
HDCP compliant
Length
20 cm
Connector
24+1 pin digital DVI - female
DisplayPort 1.1, FCC, RoHS
3-year warranty
7NZM StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
7NZM StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.55
7NZM StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.23
7NZM StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £9.73
7NZM StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black In Stock £8.04
