StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F
Quicklinx: 76S6WS00 Mfr#: GCMDP2DPMF
Type: DisplayPort
10 in stock
£19.45 ex VAT
£23.34 inc VAT
The GCMDP2DPMF Mini DisplayPort to DisplayPort adapter/converter allows you to add a standard DisplayPort connection port to your existing laptop or Mac Mini. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F - DisplayPort adapter
DisplayPort adapter
Connector
DisplayPort - female
Connector (Second End)
Mini DisplayPort - male
RoHS
P/N: DP2DVID2, DP2DVIS, DP2HDS
DisplayPort adapter
Plated Connector
Nickel
Connector
20 pin DisplayPort - female
RoHS
76S6 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.00
76S6 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
76S6 StarTech.com 25 ft DisplayPort Cable with Latches - M/M In Stock £45.83
76S6 StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.00
76S6 StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £28.51
76S6 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.10
76S6 StarTech.com 3 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.72
76S6 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.20
76S6 StarTech.com 1 ft Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.20
76S6 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.69
76S6 StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £19.45
Type: DisplayPort
Price Range Ex VAT: 0 - 50
