StarTech.com Mini DisplayPort to DisplayPort 1.4 Cable 3.1m
Quicklinx: J4L9WS00 Mfr#: DP14MDPMM10F
More than 50 In Stock
£19.03 ex VAT
£22.83 inc VAT
This 10ft Mini DisplayPort to DisplayPort v1.4 cable features a mDP male connector on one end, and a DP male latching connector on the other, allowing you to connect any Mini DisplayPort-enabled laptop or workstation to an 8K TV, monitor or projector that uses a standard DisplayPort connection. Crystal-Clear Picture Quality
This mDP to DP 1.4 cable supports high resolutions of up to 8K (7680 x 4320p) at 60Hz or 4K (3840 x 2160) at 120Hz with a maximum HBR3 bandwidth of 32.4 Gbps and ensures that digitally protected content is displayed properly, with both HDCP 2.2 and DPCP capability. The adapter cable also supports: Multi-Stream Transport (MST) for daisy chaining multiple monitors. Display Stream Compression (DSC) v1.2 transport that enables up to 3:1 compression ratio. HDR meta transport, which offers a flexible metadata packet transport to support future dynamic HDR standards. Expanded audio transport, which covers capabilities such as 32 uncompressed audio channels, 1536kHz sample rate. Forward Error Correction (FEC), which overlays the DSC 1.2 transport, addresses the transport error resiliency needed for compressed video transport to external displays.
Ultimate Compatibility
This Mini DisplayPort to DisplayPort adapter is compatible with several systems, including your PC, Mac and Microsoft Surface devices with mDP. For ultimate convenience, this Mini DisplayPort cable works with computers that are equipped with Thunderbolt 2 ports, enabling you to connect your DP compatible displays to your mDP source. In addition, this DP1.4 adapter cable supports a wide selection of mDP1.4-equipped graphics cards such as: Radeon VII, SSG, WX x100, Pro and FirePro series. Nvidia Quadro P series.
Built to Last
This Mini DisplayPort to DisplayPort v1.4 adapter cable is designed with gold-plated latching DisplayPort connectors that prevent accidental disconnection, making it a great accessory for office or boardroom applications. Having 34 AWG conductors and 4.5mm outer diameter, this slim cable offers both flexibility and ease of connection.
  • Robust construction
    The cable features gold-plated connectors which enhance durability and provide reliable signal transmission. The PVC jacket material adds to the longevity and resilience of the cable against wear and tear.
  • High bandwidth capacity
    With a maximum bandwidth of up to 32.4 Gbps, this cable allows for the transmission of high-resolution audio and video without loss of quality, making it suitable for demanding applications.
  • Enhanced audio support
    This cable supports up to 32 uncompressed digital audio channels, ensuring sound quality that complements high-definition visual content.
  • Advanced features
    The inclusion of features like Forward Error Correction and Chroma subsampling (4:4:4) improves overall data integrity and visual clarity, delivering an experience.
  • Easy connectivity
    Designed with latched connectors, this cable ensures a secure connection to avoid accidental disconnections during use, enhancing usability.
StarTech.com Mini DP to DisplayPort 1.4 Cable 8K 60Hz HBR3 4K - DisplayPort cable - Mini DisplayPort to DisplayPort - 3.1 m
DisplayPort cable
Shielded
8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, 19 conductors, HBR3 support, up to 32.4 Gbps bandwidth, Display Stream Compression 1.2 (DSC), HDR support, 32 uncompressed digital audio channels, Multi-Stream Transport, daisy-chaining, strain relief, Chroma subsampling (4:4:4), Forward Error Correction
Length
3.1 m
Connector
Mini DisplayPort - male
Connector (Second End)
20 pin DisplayPort - male - latched
Displayport 1.4/Thunderbolt 2
DisplayPort cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
34
Plated Connector
Gold
Length
3.1 m
Outside Diameter
4.5 mm
Connector
Displayport 1.4/Thunderbolt 2, RoHS, WEEE, EMI, DSC 1.2, HDCP 2.2
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
144 g
