Connect a Mini DisplayPort 1.2-equipped PC or Mac to a VGA Monitor or Projector. The MDP2VGA2 Mini DisplayPort to VGA converter enables you to connect your Mini DisplayPort video source (Laptop, Macbook, Ultrabook etc.) to a VGA monitor or projector, saving the expense of upgrading to a Mini DisplayPort compatible display. The mDP adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
With a small foot print and no external power adapter this mDP to VGA adapter ensures maximum portability making it an ideal laptop accessory.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
Versatile connectivity
This adapter allows for a simple connection between Mini DisplayPort enabled devices and VGA monitors, facilitating various display configurations. -
High-resolution support
With a maximum output resolution of 1920 x 1200, this adapter provides sharp image quality for a wide array of multimedia applications. -
Active adapter technology
Utilizing active adapter technology ensures that video signals maintain their integrity for reliable performance, essential for presentations. -
Compliance and safety
Built in accordance with FCC and RoHS standards, the adapter promotes a safer work environment while ensuring quality performance.
- StarTech.com Mini DisplayPort to VGA Adapter - DisplayPort 1.2 - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA (MDP2VGA2) - video adapter - Mini DisplayPort to HD-15 (VGA) - 22 cm
- Video adapter
- Active adapter, 1920 x 1200 (WUXGA) support
- Length
- 22 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female
- Displayport 1.2/Thunderbolt
- Black
- 3-year warranty
- Video adapter
- Length
- 22 cm
- Black
- 3.5 cm
- 0.8 cm
- 27 g
- Connector
- Displayport 1.2/Thunderbolt, FCC, RoHS
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 36 g
- 3-year warranty
StarTech.com Mini DisplayPort to VGA Video Adapter Converter | In Stock | £14.70 |
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White | In Stock | £5.38 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £17.93 |
StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 | In Stock | £14.42 |
