Connect a Mini DisplayPort 1.2-equipped PC or Mac to a VGA Monitor or Projector. The MDP2VGA2 Mini DisplayPort to VGA converter enables you to connect your Mini DisplayPort video source (Laptop, Macbook, Ultrabook etc.) to a VGA monitor or projector, saving the expense of upgrading to a Mini DisplayPort compatible display. The mDP adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
With a small foot print and no external power adapter this mDP to VGA adapter ensures maximum portability making it an ideal laptop accessory.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 1920x1200 (WUXGA).
                Versatile connectivityThis adapter allows for a simple connection between Mini DisplayPort enabled devices and VGA monitors, facilitating various display configurations.
                High-resolution supportWith a maximum output resolution of 1920 x 1200, this adapter provides sharp image quality for a wide array of multimedia applications.
                Active adapter technologyUtilizing active adapter technology ensures that video signals maintain their integrity for reliable performance, essential for presentations.
                Compliance and safetyBuilt in accordance with FCC and RoHS standards, the adapter promotes a safer work environment while ensuring quality performance.
- StarTech.com Mini DisplayPort to VGA Adapter - DisplayPort 1.2 - 1080p - Thunderbolt to VGA Monitor Adapter - Mini DP to VGA (MDP2VGA2) - video adapter - Mini DisplayPort to HD-15 (VGA) - 22 cm
- Video adapter
- Active adapter, 1920 x 1200 (WUXGA) support
- Length
- 22 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female
- Displayport 1.2/Thunderbolt
- Black
- 3-year warranty
- Video adapter
- Length
- 22 cm
- Black
- 3.5 cm
- 0.8 cm
- 27 g
- Connector
- Displayport 1.2/Thunderbolt, FCC, RoHS
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 36 g
- 3-year warranty
