Provides 4 external USB 2.0 ports in a compact and portable form factor. The ST4200MINI Mini 4 port USB hub allows you to turn a single USB connection into four USB ports, and based on a small form factor design, requires minimal space to install.
An ideal laptop accessory for maximizing the number of available USB device connections, the mini four port USB hub operates on low levels of power, helping to ensure that you get the most out of your notebook battery.
The mini four port hub supports Hi-speed USB 2.0 data transfers of up to 480 Mbps, and since the hub is backwards-compatible with previous versions of USB, your older USB peripherals will work perfectly as well.
- StarTech.com Mini 4 Port USB 2.0 Hub - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 2.0
- 9 cm x 2 cm x 1.3 cm
- Black
- System Requirements
- Apple MacOS X, Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 / XP
- 2-year warranty
- Designed For
- P/N: FCREADMICRO, USB56KEM, USB120EXT, USB110EXT, USB100EXT
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 2.0
- Status Indicators
- Power
- 4 x USB 2.0 Type A , 1 x USB 2.0 Type A
- Black
- Cables Included
- 1 x USB cable
- Plug and Play, FCC Class B certified
- OS Required
- 9 cm
- 2 cm
- 1.3 cm
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Designed For
- StarTech.com 1 Port Cat5 USB Extender, External 56K USB Modem, USB Multi Media Memory Card Reader Adapter
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £62.14 |
