StarTech.com Micro USB to RS232 DB9 Serial Adapter Cable for Android with USB Charging - M/M
Quicklinx: 9MLNWS00 Mfr#: ICUSBANDR232
Type: Serial adapter
Compatibility: Android
Interface: USB 2.0
Hurry, only 1 left in stock!
£22.04 ex VAT
£26.44 inc VAT
Add an RS232 serial port to your Android smartphone or tablet device through Micro USB with USB charging capabilities. The ICUSBANDR232 Micro USB to Serial Adapter Cable for Android converts the micro USB port on your Android mobile device into an RS232 DB9 connection, letting you control a serial device from the convenience of your smartphone or tablet.
Plus, you can keep your Android mobile device charged even when using the adapter to control or configure a serial device. The adapter cable features an integrated USB power cable that connects to a computer USB port, USB wall charger or portable USB battery pack to power the adapter.
Designed for mobility and integration into mixed environments, this portable and lightweight single cable solution is compatible with nearly all Android OS version 3.2 Honeycomb or later devices including the Samsung Galaxy Note, S5, S4, S3, or S2, Google Nexus 7, 5, or 4, and Motorola or HTC mobile devices. The versatile adapter will even work with devices that don't support USB On-The-Go (OTG)!
This Micro USB to serial adapter features an integrated FTDI USB UART Chip supporting baud rates up to 921.6 Kbps, provides serial configuration via a downloadable FTDI AOA (Android Open Accessory) HyperTerm Application, and offers standard CTS/RTS, DTR/DSR, XOFF/XON flow control.
StarTech.com Micro USB to RS232 DB9 Serial Adapter Cable for Android w/ USB Charging - M/M - Micro USB to Serial Converter for Android (ICUSBANDR232) - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232
RS-232
Data Transfer Rate
921.6 Kbps
USB 1.1, USB 2.0
Android 3.2 (Honeycomb) or later
Serial adapter
External
USB 2.0
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
USB powered
USB 1.1, USB 2.0
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type A
1 x micro-USB cable (integrated) - 1 m
FCC, RoHS
60 °C
5 - 90%
9MLN StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.53
9MLN StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.19
Interface: USB 2.0
Price Range Ex VAT: 0 - 50
