Add an RS232 serial port to your Android smartphone or tablet device through Micro USB with USB charging capabilities. The ICUSBANDR232 Micro USB to Serial Adapter Cable for Android converts the micro USB port on your Android mobile device into an RS232 DB9 connection, letting you control a serial device from the convenience of your smartphone or tablet.
Plus, you can keep your Android mobile device charged even when using the adapter to control or configure a serial device. The adapter cable features an integrated USB power cable that connects to a computer USB port, USB wall charger or portable USB battery pack to power the adapter.
Designed for mobility and integration into mixed environments, this portable and lightweight single cable solution is compatible with nearly all Android OS version 3.2 Honeycomb or later devices including the Samsung Galaxy Note, S5, S4, S3, or S2, Google Nexus 7, 5, or 4, and Motorola or HTC mobile devices. The versatile adapter will even work with devices that don't support USB On-The-Go (OTG)!
This Micro USB to serial adapter features an integrated FTDI USB UART Chip supporting baud rates up to 921.6 Kbps, provides serial configuration via a downloadable FTDI AOA (Android Open Accessory) HyperTerm Application, and offers standard CTS/RTS, DTR/DSR, XOFF/XON flow control.
- StarTech.com Micro USB to RS232 DB9 Serial Adapter Cable for Android w/ USB Charging - M/M - Micro USB to Serial Converter for Android (ICUSBANDR232) - serial adapter - USB 2.0 - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- USB 1.1, USB 2.0
- System Requirements
- Android 3.2 (Honeycomb) or later
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- USB powered
- USB 1.1, USB 2.0
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x micro-USB cable (integrated) - 1 m
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.54 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.62 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £25.80 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.40 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £15.66 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £207.06 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £332.34 |
