Connect a Micro SD card to your computer or OTG mobile device, through a USB or Micro USB port. The MSDREADU2OTG Micro SD to USB/Micro USB Adapter lets you turn a Micro SD card into an external USB storage solution that can interface with any USB-enabled computer or OTG-enabled device, such as Samsung Galaxy smartphones and tablets.
Expand the storage capabilities of your OTG-enabled smartphone or tablet, by creating an external storage device that you can also connect to your USB-enabled computer, and transfer files from one device to another with standard USB and Micro USB interface options.
Maximize portability by creating a compact, external storage solution that you can connect to your smartphone, tablet or laptop computer. For a hassle-free setup, the OTG adapter supports plug-and-play installation and is natively supported by any USB-enabled computer or any OTG-enabled mobile device.
- StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices (MSDREADU2OTG) - card reader - USB 2.0
- Product Type
- Card reader - external
- Supported Memory Cards
- miniSD, microSD
- Host Interface
- USB 2.0
- Black
- 2-year warranty
- Product Type
- miniSD, microSD
- Host Interface
- USB 2.0
- Black
- 12 mm
- 40 mm
- 5 mm
- 4 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 4 pin USB Type A , 1 x 5 pin Micro-USB Type B
- OS Required
- Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
- FCC, RoHS
- Limited warranty - 2 years
