StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080
Quicklinx: 8Y6HWS00 Mfr#: MCHD2VGAE2
£24.11 ex VAT
£28.93 inc VAT
Connect a Micro HDMI equipped Smartphone or Tablet PC to your VGA Display, or Projector. The MCHD2VGAE2 HDMI Micro to VGA adapter/converter actively converts an HDMI Micro video signal from your smartphone, Ultrabook, or tablet PC onto a VGA projector, or display. The Micro HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor.
The HDMI Micro/VGA adapter supports video resolutions up to full 1080p, making it a convenient option for high-definition applications, and features a compact design with no external power source, which ensures a portable solution that's easy to carry as an accessory.
StarTech.com Micro HDMI® to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 - Micro HDMI Male to VGA Female (MCHD2VGAE2) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15)
4.5 cm x 25.5 cm x 1.5 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200 at 60 Hz
1 x HDMI input - 19 pin micro HDMI Type D - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
FCC, RoHS
4.5 cm
25.5 cm
1.5 cm
33 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85% (non-condensing)
8Y6H StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p In Stock £14.00
8Y6H StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £24.28
8Y6H StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 In Stock £24.11
8Y6H StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.79
8Y6H StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops In Stock £14.89
8Y6H StarTech.com HDMI to VGA Adapter w/ Audio In Stock £12.56
