Connect a Micro HDMI equipped Smartphone or Tablet PC to your VGA Display, or Projector. The MCHD2VGAE2 HDMI Micro to VGA adapter/converter actively converts an HDMI Micro video signal from your smartphone, Ultrabook, or tablet PC onto a VGA projector, or display. The Micro HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor.
The HDMI Micro/VGA adapter supports video resolutions up to full 1080p, making it a convenient option for high-definition applications, and features a compact design with no external power source, which ensures a portable solution that's easy to carry as an accessory.
- StarTech.com Micro HDMI® to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 - Micro HDMI Male to VGA Female (MCHD2VGAE2) - video converter - black
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 4.5 cm x 25.5 cm x 1.5 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200 at 60 Hz
- 1 x HDMI input - 19 pin micro HDMI Type D - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 4.5 cm
- 25.5 cm
- 1.5 cm
- 33 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85% (non-condensing)
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.81 |
StarTech.com Micro HDMI to VGA Adapter Converter for Smartphones / Ultrabook / Tablet - 1920x1080 | In Stock | £22.95 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook | In Stock | £16.15 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £6.71 |
