StarTech.com Metal Cable Tie Tool - Stainless Steel Zip Ties Tightener
Quicklinx: FXZVWS00 Mfr#: CBMMCTTOOL
£66.88 ex VAT
£80.25 inc VAT
Tensioning & Cutting Tool For Metal Zip Ties Installs 316SS Stainless Steel Cable Ties. This portable cable tie installation tool, quickly and easily installs metal cable ties. An ideal accessory for StarTech.com 316SS Stainless Steel Cable Ties - 50 Pack (CBMMCT) sold separately.
Easy-To-Use
Designed with an easy-to-use one-squeeze mechanism, this cable tie gun reduces time and repetitive strain on your hands when installing many cable ties. The metal zip tie tightener adjusts the cable tie tension to perfectly suite your cable bundle, and trims excess metal from the cable tie in one motion.
Works with Various Sized Cable Ties
This versatile cable tensioning and cutting tool works with any length of cable tie wrap, and supports widths from 0.18in (4.6mm) to 0.31in (7.9mm), ensuring it can support a variety of cable ties, depending upon your application.
Use with StarTech.com 316SS Stainless Steel Cable Ties
The cable tie installation tool is an ideal accessory for StarTech.com 316SS Stainless Steel Ties - 50 Pack (CBMMCT) that are nylon 11 coated for abrasion & weather resistance (sold separately).
This metal cable tie installation tool is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Easy-to-use
  • Works with various sized cable ties
    This versatile cable tensioning and cutting tool works with any length of cable tie wrap, ensuring it can support a variety of cable ties, depending upon your application.
StarTech.com Metal Cable Tie Tool, Metal Zip Tie Tightener Tool, Stainless Steel Cable Tie Installation Gun, Tensioning and Cutting Zip Ties Tool, Tensioner and Cutter for Metal Tie Wrap - 316SS Cable Tie Gun (CBMMCTTOOL) - cable tie installation tool - TAA Compliant
Cable tie installation tool
21 cm x 15.5 cm x 4 cm
615 g
TAA Compliant
21 cm
15.5 cm
4 cm
615 g
Enclosure Colour
TAA Compliant
Shipping Width
21.5 cm
Shipping Depth
13.2 cm
Shipping Height
4.6 cm
Shipping Weight
620 g
FXZV StarTech.com Metal Cable Tie - 50 Pack In Stock £41.78
FXZV StarTech.com 20-Bit Electric Precision Screwdriver Set In Stock £43.02
FXZV StarTech.com 55-Bit Electric Precision Screwdriver Set In Stock £59.62
FXZV StarTech.com Nylon Cable Tie Gun/Tool In Stock £23.33
