StarTech.com Metal Cable Tie - 50 Pack
Quicklinx: FXZTWS00 Mfr#: CBMMCT
£40.77 ex VAT
£48.92 inc VAT
50 Pack 9 in. (225 mm) 316SS Stainless Steel Nylon 11 Coated. These stainless steel metal cable ties provide a strong solution to conveniently bundle and secure multiple cables, and to route and organize them. 50 cable ties are included, ensuring you'll have plenty on hand.
Keep Cables Organized with Durable Metal Ties
These stainless steel cable ties are 9 in. (225 mm) in length securing cable bundles up to 2.28in (58mm) in diameter and up to 110 lbs. (50 kg) - perfect for organizing network cables, power cables or other cables and wires.
Industrial Strength for Indoor or Outdoor Use
Made of 316SS and Nylon 11 coated, these stainless steel ties are non-abrasive and weather, corrosion and impact resistant, making them suitable for any indoor or outdoor cable management solution, including marine applications. They're also metal detectable for use with fiber optic cables.
Easy to Install By Hand, or Using the StarTech.com Metal Cable Tie Tool
These stainless steel ties can easily be installed by hand. However, to reduce time and repetitive strain on your hands when installing many cable ties, StarTech.com also offers a Metal Cable Tie Tool (CBMMCTTOOL), that works with our cable ties as well as other metal cable ties (sold separately).
These cable wraps are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Keep cables organized with durable metal ties
    These stainless steel cable ties secure cable bundles - perfect for organizing network cables, power cables or other cables and wires.
  • Industrial strength for indoor or outdoor use
    Made of 316SS and nylon 11 coated, these stainless steel ties are non-abrasive and weather-, corrosion- and impact-resistant, making them suitable for any indoor or outdoor cable management solution, including marine applications. They're also metal detectable for use with fiber optic cables.
StarTech.com 9"(22cm) Metal Cable Ties, 1/4"(7mm) wide, 2-1/4"(55mm) Bundle Dia. 100lb(45kg) Tensile Strength, Nylon Coated 316 Stainless Steel, Self Locking Metal Detectable Ties, 50 Pack - Nylon 11 Coated Ties (CBMMCT) - cable tie - TAA Compliant
Cable tie
Packaged Quantity
50 (specifications are for single item)
Indoor / Outdoor
Indoor, outdoor
1.2 cm 0.28 cm
Length
22.5 cm
8.2 g
Product Material
316 grade stainless steel, nylon 11
TAA Compliant
P/N: CBMMCTTOOL
Packaged Quantity
Cable tie
Indoor / Outdoor
Indoor, outdoor
Product Material
1.2 cm
0.28 cm
Length
22.5 cm
8.2 g
Enclosure Colour
Self-locking, for cable diameter 58 mm
TAA Compliant
Shipping Width
22.5 cm
Shipping Depth
7 cm
Shipping Height
1 cm
Shipping Weight
420 g
P/N: CBMMCTTOOL
FXZT StarTech.com Metal Cable Tie Tool - Stainless Steel Zip Ties Tightener In Stock £65.54
FXZT StarTech.com 100 Pack of Plastic Zip Ties With Screw Hole - 4" In Stock £4.03
