StarTech.com mDP to HDMI or VGA Converter
Quicklinx: B67XWS00 Mfr#: MDP2HDVGAW
10 In Stock
£13.32 ex VAT
£15.98 inc VAT
Connect your Mini DisplayPort equipped PC or Mac to an HDMI or VGA display. The MDP2HDVGA Mini DisplayPort travel adapter lets you connect your DP enabled Ultrabook or laptop computer to any VGA or HDMI display. The sleek adapter features an all-white design that looks great when interfaced with your MacBook Pro or MacBook Air.
Why carry multiple adapters when you only need one? Instead of keeping two different adapters on-hand, DP travel adapter offers both VGA and HDMI outputs, so you'll be able to connect from your laptop to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports high video resolutions you can convert a Mini DisplayPort video source to HDMI or VGA without sacrificing video quality. The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
StarTech.com Mini DisplayPort to HDMI and VGA Adapter - Mini DisplayPort Multiport Hub for Your HDMI or VGA Monitor / Display (MDP2HDVGAW) - video converter - white
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
10.5 cm x 25 cm x 2.36 cm
Enclosure Colour
White
3-year warranty
Apple MacBook Air
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
FCC, RoHS
10.5 cm
25 cm
2.36 cm
Enclosure Colour
White
Limited warranty - 3 years
60 °C
10 - 85%
Apple MacBook Air
B67X StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £20.15
B67X StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £9.27
B67X StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.35
B67X StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.03
B67X StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £7.58
B67X StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £31.29
B67X StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £20.60
B67X StarTech.com mDP to HDMI or VGA Converter In Stock £17.62
B67X StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
B67X StarTech.com DP to HDMI or VGA Converter In Stock £16.21
B67X StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £54.74
