Connect your Mini DisplayPort equipped PC or Mac to an HDMI or VGA display. The MDP2HDVGA Mini DisplayPort travel adapter lets you connect your DP enabled Ultrabook or laptop computer to any VGA or HDMI display. The sleek adapter features an all-white design that looks great when interfaced with your MacBook Pro or MacBook Air.
Why carry multiple adapters when you only need one? Instead of keeping two different adapters on-hand, DP travel adapter offers both VGA and HDMI outputs, so you'll be able to connect from your laptop to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports high video resolutions you can convert a Mini DisplayPort video source to HDMI or VGA without sacrificing video quality. The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
- StarTech.com Mini DisplayPort to HDMI and VGA Adapter - Mini DisplayPort Multiport Hub for Your HDMI or VGA Monitor / Display (MDP2HDVGAW) - video converter - white
- Video converter
- Graphics Engine
- - up to
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 10.5 cm x 25 cm x 2.36 cm
- Enclosure Colour
- White
- 3-year warranty
- Designed For
- Apple MacBook Air
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 10.5 cm
- 25 cm
- 2.36 cm
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 10 - 85%
- Designed For
- Apple MacBook Air
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter | In Stock | £20.33 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £9.42 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.74 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.78 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £31.58 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £8.34 |
StarTech.com mDP to HDMI or VGA Converter | In Stock | £13.32 |
StarTech.com DP to HDMI or VGA Converter | In Stock | £16.54 |
