Connect three HDMI enabled monitors to your laptop or Ultrabook, through a single Mini DisplayPort output. This MST hub lets you connect three HDMI monitors to your Mini DisplayPort (mDP) 1.2 equipped Windows laptop or desktop.
The hub features a newly engineered chipset that was specifically designed and rigorously tested to resolve compatibility issues with the Microsoft Surface Pro 3.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. You can also mirror the same image onto multiple HDMI televisions or projectors for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTMDP123HD will act as a splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTMDP123HD supports plug-and-play installation for a hassle-free setup.
Increase your productivity with multiple monitors
The newest generations of laptops are more portable than ever, unfortunately this means you're left with fewer video outputs and a small integrated screen. The MST hub solves these problems by letting you connect three independent displays to a single mDP port on your computer, which makes multitasking much easier. Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display, which makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot desk solution with a wireless keyboard and mouse peripheral set. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage. -
Astonishing picture quality that won't drain your system resources
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and delivers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and medical imaging. The MSTMDP123HD is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com 3 Port Mini DisplayPort MST Hub - 4K 30Hz - Mini DP to HDMI Video Splitter for Multiple Monitors - mDP to HDMI (MSTMDP123HD) - video/audio splitter - 3 ports
- Video/audio splitter - 3 ports
- Subtype
- HDMI / DisplayPort
- Ports
- 3 x HDMI
- Plastic housing
- Power
- AC 100/240 V
- 6.6 cm x 11.4 cm x 1.4 cm
- 119 g
- Black
- System Requirements
- Windows 10 (32/64 bits), Microsoft Windows 7 / 8 / 8.1 (32 bits), Microsoft Windows 7 / 8 / 8.1 (64 bits)
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- Ports
- 3 x HDMI
- Max Resolution
- 3840 x 2160 @ 30 Hz
- Plastic housing
- 3 x HDMI output , 1 x mini-DisplayPort input
- Power Device
- External power adapter
- Voltage Required
- AC 100/240 V
- Black
- FCC, RoHS
- OS Required
- 6.6 cm
- 11.4 cm
- 1.4 cm
- 119 g
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 50 - 90%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.60 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.55 |
StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £54.73 |
StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £38.03 |
StarTech.com MST Hub - mDP to 2x DP | In Stock | £33.69 |
StarTech.com MST Hub - 4-Port DisplayPort | In Stock | £65.23 |
StarTech.com MST Hub - 2-Port DisplayPort | In Stock | £40.09 |
StarTech.com MST Hub - mDP to 4x DP | In Stock | £47.11 |
StarTech.com mDP 1.2 to HDMI MST Hub | In Stock | £33.29 |
StarTech.com USB-C to DisplayPort MST Hub - 2-Port | In Stock | £38.47 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.00 |
StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor | In Stock | £52.56 |
StarTech.com DP 1.4 to Dual HDMI MST Hub | In Stock | £32.55 |
