Sometimes the best solutions are the easiest - like this dry erasable magnetic project mat that gives you an easy way to keep tiny screws and other small parts organized. It's an ideal tool for assembly or repair of smart phones, laptops, drive enclosures, drones, small form factor robotics or other small electronics.
Now when you are assembling or taking devices apart, you can keep the parts in order. Screws and other small items are held in one place on the slightly magnetized tool pad, helping to prevent loss or errors.
The electronics repair mat also works as a magnetic dry erase sheet, so you can write down project notes to keep everything on track (marker included). You can jot down the screw locations, to save time on repairs and refurbs.
The 9.5" x 10.5" (24 cm x 27 cm) magnetic project mat provides an effective work surface, with a 2.2 mm thickness. Its compact size works well for stationary or portable use.
The electronics repair mat, made of magnetic rubber with a white PVC top surface, provides durability with a surface that wipes off easily.
- StarTech.com Magnetic Project Mat - magnetic pad
- Product Type
- Magnetic pad - 240 x 270 mm
- Package Content
- Marker
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Product Type
- Magnetic pad
- Package Content
- Marker
- Size
- 240 x 270 mm
- Dry erase surface
- Warranty
- 5 years
- 2.2 mm
StarTech.com 20-Bit Electric Precision Screwdriver Set | In Stock | £41.98 |
StarTech.com 55-Bit Electric Precision Screwdriver Set | In Stock | £58.18 |
StarTech.com 23x47in Anti Static Mat | In Stock | £42.78 |
StarTech.com 11x18in Anti Static Mat | In Stock | £24.24 |
