StarTech.com MA-SFP-1GB-TX Compatible SFP
Quicklinx: CRGNWS00 Mfr#: MASFP1GBTXST
Type: Modules
£38.74 ex VAT
£46.48 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections with this SFP module. This Cisco Meraki compatible copper SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality Gb RJ45 copper SFP can be installed into Cisco Meraki networking devices that support the Cisco Meraki MA-SFP-1GB-TX transceiver module, as well as other major brands of networking equipment.
The SFP transceiver provides 10Base-T / 100Base-TX / 1000Base-T throughput over a distance of up to 100 m (328 ft.) using a copper RJ-45 connection. It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your networking equipment.
This Gigabit RJ45 copper SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% Cisco Meraki compatible, equivalent to the Cisco Meraki MA-SFP-1GB-TX transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with Cisco Meraki or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a multitude of multi and single-port Gigabit Ethernet networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP provides reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports auto-negotiation, maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
  • Robust Construction
    This SFP transceiver module features a durable design that withstands operating temperatures from 0°C to 70°C, ensuring reliable performance in challenging environments.
  • Efficient Networking
    With a data transfer rate of 1 Gbps, this module enhances network performance, supporting quick data exchange and improved communication.
  • Versatile Compatibility
    Equipped with an RJ-45 connector, this module integrates easily into existing Ethernet setups, making it suitable for a range of applications.
  • Compliance with Standards
    The module meets several important standards including UL, FCC, RoHS, and MSA, ensuring safe and efficient operation in various settings.
StarTech.com Cisco Meraki MA-SFP-1GB-TX Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 10/100/1000 Mbps, RJ-45 (Copper) 100m, Cisco Meraki MS225, MX400, MS250, 1GbE Mini GBIC - Lifetime Warranty (MASFP1GBTXST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
1.37 cm x 6.8 cm x 1.38 cm
35 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
100 m
Auto-negotiation, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female
UL, FCC, RoHS, MSA
1.37 cm
6.8 cm
1.38 cm
35 g
Limited warranty - lifetime
70 °C
5 - 95%
CRGN StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £32.38
CRGN StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £146.68
CRGN StarTech.com Fiber Media Converter - Open In Stock £44.55
CRGN StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £338.20
Type: Modules
