Add reliable and cost-effective 10 Gigabit Ethernet connections over multimode fiber with this SFP+ module. This StarTech.com 10 Gigabit fiber SFP+ is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco Meraki switches and routers that support the Cisco Meraki MA-SFP-10GB-SR SFP+ transceiver module, as well as other major brands of networking equipment.
The 10GBase-SR SFP+ delivers 10 Gigabit connectivity over multi-mode fiber cable with a range of up to 300 m (984 ft). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The 10 Gigabit multi-mode SFP+ is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco Meraki MA-SFP-10GB-SR SFP+ transceiver. The StarTech.com SFP+ is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP+ products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in Cisco switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The multi-mode fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 300 m (984 ft), and maximum data rates of up to 10Gbps.
High-speed connectivity
The SFP+ transceiver module provides a data transfer rate of 10 Gbps, ensuring efficient network performance. -
Broad compatibility
This module is compatible with systems that support 10 Gigabit Ethernet, making it a versatile option for many network setups. -
Environmentally resilient
Designed to operate in a range of temperatures, the module functions effectively in environments from 0°C to 70°C. -
Monitoring capabilities
With built-in Digital Diagnostics Monitoring (DDM), users can track performance metrics and optimize network operations. -
Extended range
The optical wavelength of 850 nm allows for a maximum transfer distance of 300 meters, suitable for network configurations.
- StarTech.com Cisco Meraki MA-SFP-10GB-SR Compatible SFP+ Module, 10GBASE-SR, 10GbE MMF Optic Transceiver, 10GE Gigabit Ethernet, LC Connector, 300m 850nm Cisco Meraki MS225, MX400, MS250 (MASFP10GBSR) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- OEM Manufacturer Equivalent Part Number
- Cisco Meraki MA-SFP-10GB-SR
- 1.39 cm x 5.84 cm x 1.26 cm
- 30 g
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 850 nm
- 300 m
- Digital Diagnostics Monitoring (DDM), full duplex mode
- IEEE 802.3ae
- 1 x Ethernet 10GBase-SR - LC multi-mode female x 2
- RoHS, MSA, UL, FCC
- 1.39 cm
- 5.84 cm
- 1.26 cm
- 30 g
- 0 °C
- 70 °C
- 5 - 95%
StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £18.69 |
StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £23.62 |
StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £33.25 |
StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £16.47 |
StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £24.53 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
