Mount server, telecom and A/V equipment with these high quality mounting screws and nuts. This 20-pack of M6 rack screws and M6 cage nuts is convenient to have on hand for installing rack-mountable equipment, such as your server, network or audio/video equipment. Each pack includes a cage nut installation tool to ensure a fast and simple installation of each cage nut.
The cabinet mounting screws and cage nuts are also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a nut or two. The bulk pack ensures that you have enough available when you need them.
The M6 mounting screws and the M6 nuts come in a nickel-plated finish to prevent rust.
Assembly solution
This product includes enough components for secure mounting in various cabinet types, making it versatile for different applications. -
Durable nickel plated finish
The nickel plating on the screws and nuts provides protection against wear and tear, prolonging the life of your installation.
- Startech Rack Screws - 20 Pack - Installation Tool - 12 mm M6 Screws - M6 Nuts - Cabinet Mounting Screws and Cage Nuts (CABSCRWM620) - rack screws and nuts
- Product Type
- Rack screws and nuts
- Packaged Quantity
- 20 (specifications are for single item)
- Package Content
- 20 M6 cage nuts, 20 M6 screws
- Silver
- 2-year warranty
- Packaged Quantity
- Product Type
- Package Content
- Silver
- Finish
- Nickel plated
- Limited warranty: - 2 years
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £94.63 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £41.63 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £68.51 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £45.84 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.20 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £100.66 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £514.25 |
StarTech.com 50 PKG 10-32 Screws & Nuts | In Stock | £29.50 |
