StarTech.com M.2 to U.3 Adapter/Converter
Quicklinx: HFNMWS00 Mfr#: 1M25-U3-M2-ADAPTER
Hurry, only 2 left in stock!
£29.75 ex VAT
£35.70 inc VAT
Convert and connect a PCIe M.2 NVMe/AHCI SSD to a 2.5inch form factor to install in a U.3 drive bay or backplane.
  • Adapt While Retaining Performance
    Change the form factor of a 2242, 2260, or 2280 M.2 NVMe drive while maintaining PCIe Gen 4 read and write speeds. This adapter has been designed with no chipset to maintain performance when adapting an M.2 drive to a 2.5-inch form factor.
  • Hassle-Free Setup
    The M.2 to U.3 Host Adapter is compatible with all operating systems, including Windows, macOS, and Linux. No additional drivers or software for installation and operation. The adapter includes M.2 drive and U.3 adapter mounting hardware.
  • Compatibility
    The M.2 to U.3 Host Adapter is backward compatible with earlier versions of M.2 PCIe NVMe drives. It is not compatible with SATA or SAS host controllers, M.2 SATA SSDs, or U.2 host interfaces.
StarTech.com M.2 to U.3 Adapter, For M.2 NVMe SSDs, PCIe M.2 Drive to 2.5inch U.3 (SFF-TA-1001) Host Adapter/Converter, TAA Compliant - 2.5" Drive Form Factor (1M25-U3-M2-ADAPTER) - interface adapter - M.2 NVMe Card / PCIe 4.0 (NVMe) - U.3 - TAA Compliant
Interface adapter - external
Bus Type
U.3
Red
Expansion Bays
1 x internal - M.2 2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
Supported Devices
Solid state drive
Max Storage Devices Qty
1
TAA Compliant
7 cm x 10 cm x 0.7 cm
37 g
M.2
Host Bus
U.3
Red
Storage Controller
Supported Devices
Solid state drive
1
Bays
1 x M.2 Card - M.2 M key (internal)
1 x U.3 NVMe - U.3 (SFF-TA-1001)
Supports NVM Express, S.M.A.R.T. support, 60 cycles insertion rating
Mounting Kit
Included
MTBF
12,368,734 hours
RoHS, WEEE, FCC
Environmental Standards
TAA Compliant
7 cm
10 cm
0.7 cm
37 g
Shipping Width
14.2 cm
Shipping Depth
17.5 cm
Shipping Height
3 cm
Shipping Weight
100 g
50 °C
15 - 90% RH
HFNM StarTech.com U.3 to PCIe Adapter Card In Stock £33.09
