StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2
Quicklinx: FLYTWS00 Mfr#: SM21BMU31CI3
Type: Storage enclosure
HD Size: M.2
40 in stock
£24.39 ex VAT
£29.26 inc VAT
Add high-performance external data storage to your USB-C laptop, tablet or desktop computer, with this SATA M.2 SSD enclosure. It lets you use your SATA M.2 drive as an ultra-fast external storage solution over a USB 3.1 Gen 2 connection. It's ideal for your MacBook, Dell XPS, Chromebook Pixel or other USB Type-C device.
The compact M.2 SATA to USB adapter is easily portable and gives you high-speed access to your data, wherever you go. The integrated USB-C cable (6"/15.2 cm), means you're always ready to plug it in, without having to remember to bring along a cable.
The sturdy aluminum and plastic enclosure encases your M.2 SATA SSD and features built-in ventilation that improve heat dissipation to help keep your drive at a suitable operating temperature.
Easily use your M.2 SATA drive as external data storage. This M.2 NGFF SSD enclosure provides a simple connection to your M.2 SATA SSD over USB 3.1 Gen 2. You can transfer files quickly, without bottlenecks, using a SATA M.2 SSD as your external drive.
The enclosure supports common M.2 SATA SSDs and multiple drive lengths, including: 42 mm (2242), 60 mm (2260), and 80 mm (2280). The USB to M.2 SATA enclosure works with USB-C host devices and is also compatible with Thunderbolt 3 USB-C ports.
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB-C - storage enclosure - M.2 Card - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Expansion Bays
1 x internal - M.2 2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
Power Source
USB bus
11 cm x 5 cm x 1.4 cm
95 g
M.2
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Storage Controller
M.2 Card
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1
JMicron JMS580
Bays
1 x M.2 Card - NGFF B + M key (internal)
1 x USB 3.1 (Gen 2) - 24 pin USB-C
Screwdriver, 4 x screws, mounting hardware
1 x USB-C cable - integrated - 14.5 cm
LED indicator
Mounting Kit
Included
MTBF
50,000 hours
UASP (USB Attached SCSI Protocol)
Power Source
USB bus
11 cm
5 cm
1.4 cm
95 g
Shipping Width
16.8 cm
Shipping Depth
9.8 cm
Shipping Height
3 cm
Shipping Weight
100 g
5 °C
35 °C
20 - 80%
HD Size: M.2
Price Range Ex VAT: 0 - 50
