StarTech.com M.2 SATA Enclosure with USB-C
Quicklinx: C194WS00 Mfr#: SM21BMU31C3
Type: Storage enclosure
HD Size: M.2
£25.79 ex VAT
£30.94 inc VAT
Turn your M.2 NGFF SATA drive into an ultra-fast, ultra-portable storage solution for USB-C enabled devices. This compact M.2 SSD enclosure lets you add highly portable data storage to any laptop or computer with a USB-C port - such as MacBook, Chromebook Pixel, Dell XPS laptops, and many others. It turns your SATA M.2 drive into a high-speed storage solution over a USB 3.1 Gen 2 connection, at up to 10Gbps throughput.
This slim, pocket-sized M.2 NGFF SSD enclosure has been specially designed for mobility, with a small form factor design that fits easily into your laptop bag. Its lightweight yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move.
Ventilation holes help to dissipate heat and help ensure an optimum operating temperature.
Leverage the speed of your M.2 NGFF SATA drive with this external enclosure. It delivers USB 3.1 Gen 2 data transfer speeds up to 10Gbps as well as UASP support, so you can achieve higher transfer speeds when you connect it to a UASP-enabled host computer.
The enclosure works with tablets, laptops and desktop computers and is compatible with hosts equipped with Thunderbolt 3 USB-C ports.
The enclosure is compatible with all of the common M.2 SSDs, and enables you to mount multiple drive lengths, including: 30mm (2230), 42mm (2242), 60mm (2260), and 80mm (2280).
StarTech.com M.2 SSD Enclosure for M.2 SATA SSD - USB 3.1 with USB-C Cable - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage enclosure - external
Bus Type
USB 3.1 (Gen 2)
Black, silver
Expansion Bays
1 x internal - M.2
Hard Drive Form Factor Compatibility
M.2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
8 cm x 1.2 cm x 9.85 cm
55 g
M.2
Host Bus
USB 3.1 (Gen 2)
Product Material
Aluminium
Black, silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1
ASMedia ASM1153
Bays
1 x internal - M.2
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 24 pin USB-C
Screwdriver, screws
1 x USB cable - external
USB powered, UASP transfer protocol, ventilation holes
FCC, RoHS
8 cm
1.2 cm
9.85 cm
55 g
10 - 90%
HD Size: M.2
Price Range Ex VAT: 0 - 50
