StarTech.com M.2 NVMe SSD to PCIe x4 Slot
Quicklinx: HHXCWS00 Mfr#: M2-REMOVABLE-PCIE-N1
Type: Interface adapter
HD Size: M.2
12 In Stock
£89.53 ex VAT
£107.43 inc VAT
  • Installation Without Tools
    Install the M.2 drive in the tray and insert the tray into the drive bay, no tools required. The drive tray features a power/activity LED indicator to monitor drive status. An optional lockable locking mechanism (2 keys included) prevents theft of mission-critical data storage devices.
  • Optimal Performance
    The ventilated stainless steel chassis and thermally cushioned tray promote heat dissipation, ensuring optimal, reliable performance and reducing potential thermal throttling. Anti-vibration springs on the tray reduce impact during installation and improve the overall stability and longevity of the hard drive. A low-profile bracket for small form factor systems is included.
  • Hot-Swap
    Additional drive trays (TR-M2-REMOVABLE-PCIE, coming soon) offer flexibility and convenience in managing multiple M.2 drives. NVMe PCIe hot swap support depends on the motherboard. Check with your motherboard manufacturer for hot swap support, and for instructions on how to enable this feature.
StarTech.com M.2 NVMe SSD to PCIe x4 Mobile Rack/Backplane with Removable Tray for PCI Express Expansion Slot, Tool-less Installation, PCIe 4.0/3.0 Hot-Swap Drive Bay, Key Lock - 2 Keys Included - interface adapter - M.2 NVMe Card / PCIe 4.0 (NVMe) - PCIe 4.0 x4
Interface adapter - plug-in card
Bus Type
PCIe 4.0 x4
Black, silver
Expansion Bays
1 x internal - M.2 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
64 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Stainless steel
1.9 cm x 16.7 cm x 12 cm
65 g
StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector (FANCASE)
M.2
Host Bus
PCIe 4.0 x4
Product Material
Stainless steel
Black, silver
Storage Controller
Data Transfer Rate
64 Gbit/s
Supported Devices
Solid state drive
1
Bays
1 x M.2 Card - M.2 M key (internal)
1 x PCIe 4.0 x4
Low-profile bracket, 2 security keys
Key lock, LED indicator, hot-swappable strorage bay, S.M.A.R.T. support, supports NVM Express, bus powered, TRIM support, 4Kn drive compatible, tool-less installation, anti-vibration springs
MTBF
10,000 hours
RoHS, WEEE
1.9 cm
16.7 cm
12 cm
65 g
Shipping Width
4.6 cm
Shipping Depth
23 cm
Shipping Height
15.1 cm
Shipping Weight
215 g
65 °C
0 - 90% RH
HHXC StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector In Stock £6.95
HD Size: M.2
