This rugged M.2 NVMe PCIe SSD enclosure is a highly portable, high-performance data storage solution for your USB-C or Thunderbolt 3 enabled devices.
                Unparalleled PerformanceLeverage the high speeds of your M.2 NVMe drive, with this external SSD enclosure. It delivers USB 3.1 Gen 2 read/write speeds up to 10Gbps, nearly twice the capability of traditional M.2 SATA and hard drive enclosures. This fan-less solid aluminum enclosure features an internal thermal pad that transfers heat away from the drive for maximum heat dissipation, ensuring your drive operates noiselessly at an optimal temperature to preserve performance.
                Dustproof and Water ResistantBe prepared for the unexpected. The enclosure for PCI Express based NVMe SSDs comes with an IP67 rating, which means that it's both dustproof and water resistant. It's the perfect solution for people who work outside. Or, for people who work in environments with a lot of dust, like: construction sites, factories, or manufacturing facilities.
                Broad CompatibilityThe USB 3.1 Gen 2 NVMe enclosure works with tablets, laptops, desktop computers and hosts that are equipped with USB Type-C and Thunderbolt 3 ports. It's also backward compatible with USB 3.1 Gen 1, making it a convenient solution for the office or other environments.
                The Choice of IT Pros Since 1985StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. M2E1BRU31C is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB-C 10Gbps M.2 NVMe PCIe SSD Enclosure, Rugged Aluminum External M.2 PCIe M-Key Case IP67 Rated, 1GB/s Read/Write, Supports 2230/2242/2260/2280, TB3 Compatible, Mac/PC - 1.6ft USB-C Cable Incl - storage enclosure - M.2 Card - USB 3.2 (Gen 2)
- Storage enclosure - external
- Bus Type
- USB 3.2 (Gen 2)
- Black
- Expansion Bays
- 1 x internal - M.2 2230/2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- M.2 Card
- Data Transfer Rate
- 10 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- 10.5 cm x 4.5 cm x 1.4 cm
- 100 g
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
- M.2
- Host Bus
- USB 3.2 (Gen 2)
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- M.2 Card
- 10 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Processor
- JMicron JMS583
- Bays
- 1 x PCIe 3.0 - M.2 NGFF M Key
- Connections
- 1 x USB 3.2 (Gen 2) - 24 pin USB-C
- Included Accessories
- Screwdriver, rubber feet, drive mounting stand-off
- Cables Included
- 1 x USB-C cable - external - 5 cm
- UASP transfer protocol, bus powered, 4Kn drive compatible
- MTBF
- 50,000 hours
- FCC, RoHS, WEEE, REACH
- Limited warranty - 2 years
- 10.5 cm
- 4.5 cm
- 1.4 cm
- 100 g
- Shipping Width
- 17 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 220 g
- 5 °C
- 35 °C
- 20 - 80%
- Designed For
- P/N: PEXUSB321C
|  | StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.60 |
|  | StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.20 |
|  | StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £12.46 |
|  | StarTech.com 0.5m USB to USB-C Cable 10Gbps | In Stock | £8.39 |
|  | StarTech.com 4x M.2 PCIe to TB3 Enclosure | In Stock | £301.29 |
