StarTech.com M.2 NVMe Duplicator Dock
Quicklinx: HSTMWS00 Mfr#: M2-HDD-DUPLICATOR-N1
35 In Stock
£118.20 ex VAT
£141.84 inc VAT
High-Speed M.2 NVMe Duplication
Clone or duplicate M.2 NVMe solid-state drives (SSDs) without the need for a computer. This device requires no drivers or software and offers high-performance sector-by-sector duplication rates of up to 90GBpm and works with any file format, copying the entire drive.
NVMe Drive Access over USB 3.2 Gen2x2
The USB 20Gbps host connection enables external access and storage functionality for M.2 NVMe drives, facilitating data transfer between different computers without the need for internal drive installation.
Compact and User-Friendly
The device has a small form factor, requiring minimal desktop or storage space. LEDs display progress, status, and power, while an audible buzzer confirms duplication completion. The device features active and passive cooling to ensure optimal performance. The top-loading (toaster-style) design accommodates all PCIe M.2 (M-Key) drives, including those with pre-installed heat sinks. The device supports 4Kn sector size. Please note that the target disk must be equal to or larger than the source disk.
  • Efficient duplication
    With a duplication speed of 90 GBpm, this standalone M.2 NVMe Drive Duplicator and Dock offers a fast and reliable solution for cloning your NVMe drives, ensuring quick data transfer and replication without the need for a host computer.
  • Versatile connectivity
    Equipped with both USB-C to USB-C and USB-C to USB-A cables, this device provides flexible connection options to suit a variety of systems and setups, making it a versatile tool for data management.
  • Comprehensive compatibility
    Supporting M.2 form factors ranging from 2230 to 22110 and interfaces including PCI Express (NVMe) and SATA 6 Gb/s, this duplicator and dock is designed to accommodate a wide range of NVMe drives, ensuring broad compatibility.
  • Durable design
    Featuring a plastic housing with a built-in 60 mm fan, buzzer, and status LED, this device is built for durability and reliability. The sector by sector duplication mode and support for AHCI mode further enhance its functionality and performance.
  • User-friendly operation
    This device simplifies the cloning process with its clone function, allowing for easy operation. The inclusion of environmental operating ranges and an external power adapter ensures stable performance under various conditions.
StarTech.com 1:1 Standalone M.2 NVMe Drive Duplicator and Dock - solid state / hard drive duplicator - TAA Compliant
Solid state / hard drive duplicator
2 (max)
Supported Drives
PCIe (NVMe)
Duplication Speed
90 GBpm
Australia, New Zealand, North America, United Kingdom, Europe
Built-in Devices
Status LED, buzzer, 60 mm fan
Storage Controller
NVMe (PCI Express (NVMe))
Hard Drive
No HDD
AC 100-240 V
TAA Compliant
7.7 cm x 7.7 cm x 4.4 cm
129 g
Duplication Speed
90 GBpm
Enclosure Colour
Chassis
Built-in Devices
Supported Devices / Modules Qty
2
Supported Drives
PCIe (NVMe)
CPU
1 x JMicron JMS586U
Storage Controller
NVMe
Interface Type
PCI Express (NVMe)
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) x external - M.2 2230/2242/2260/2280/22110
2 x SATA 6Gb/s (replication) - 75 pin M.2 M-Key , USB 3.2 Gen 2 (1 rear) - 24 pin USB-C
Supports AHCI mode, clone function, plastic housing, sector by sector duplication mode
1 x USB-C to USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1 m
MTBF
50,000 hours
RoHS, WEEE
TAA Compliant
External power adapter
AC 100-240 V
0.1 Watt
7.7 cm
7.7 cm
4.4 cm
129 g
Shipping Width
16 cm
Shipping Depth
9 cm
Shipping Height
9.5 cm
Shipping Weight
500 g
5 °C
55 °C
20 - 80% RH
HSTM StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C In Stock £44.81
HSTM StarTech.com USB PCIE/SATA M.2 Enclosure In Stock £43.99
