High-Speed M.2 NVMe Duplication
Clone or duplicate M.2 NVMe solid-state drives (SSDs) without the need for a computer. This device requires no drivers or software and offers high-performance sector-by-sector duplication rates of up to 90GBpm and works with any file format, copying the entire drive.
NVMe Drive Access over USB 3.2 Gen2x2
The USB 20Gbps host connection enables external access and storage functionality for M.2 NVMe drives, facilitating data transfer between different computers without the need for internal drive installation.
Compact and User-Friendly
The device has a small form factor, requiring minimal desktop or storage space. LEDs display progress, status, and power, while an audible buzzer confirms duplication completion. The device features active and passive cooling to ensure optimal performance.
The top-loading (toaster-style) design accommodates all PCIe M.2 (M-Key) drives, including those with pre-installed heat sinks. The device supports 4Kn sector size. Please note that the target disk must be equal to or larger than the source disk.
Efficient duplication
With a duplication speed of 90 GBpm, this standalone M.2 NVMe Drive Duplicator and Dock offers a fast and reliable solution for cloning your NVMe drives, ensuring quick data transfer and replication without the need for a host computer. -
Versatile connectivity
Equipped with both USB-C to USB-C and USB-C to USB-A cables, this device provides flexible connection options to suit a variety of systems and setups, making it a versatile tool for data management. -
Comprehensive compatibility
Supporting M.2 form factors ranging from 2230 to 22110 and interfaces including PCI Express (NVMe) and SATA 6 Gb/s, this duplicator and dock is designed to accommodate a wide range of NVMe drives, ensuring broad compatibility. -
Durable design
Featuring a plastic housing with a built-in 60 mm fan, buzzer, and status LED, this device is built for durability and reliability. The sector by sector duplication mode and support for AHCI mode further enhance its functionality and performance. -
User-friendly operation
This device simplifies the cloning process with its clone function, allowing for easy operation. The inclusion of environmental operating ranges and an external power adapter ensures stable performance under various conditions.
- StarTech.com 1:1 Standalone M.2 NVMe Drive Duplicator and Dock - solid state / hard drive duplicator - TAA Compliant
- Solid state / hard drive duplicator
- Black
- Installed Devices / Modules Qty
- 2 (max)
- Supported Drives
- PCIe (NVMe)
- Duplication Speed
- 90 GBpm
- Localisation
- Australia, New Zealand, North America, United Kingdom, Europe
- Built-in Devices
- Status LED, buzzer, 60 mm fan
- Storage Controller
- NVMe (PCI Express (NVMe))
- Hard Drive
- No HDD
- Power
- AC 100-240 V
- TAA Compliant
- 7.7 cm x 7.7 cm x 4.4 cm
- 129 g
- 2-year warranty
- Duplication Speed
- 90 GBpm
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Supported Devices / Modules Qty
- 2
- Supported Drives
- PCIe (NVMe)
- CPU
- 1 x JMicron JMS586U
Storage Controller
- NVMe
- Interface Type
- PCI Express (NVMe)
Hard Drive
- No HDD
- Expansion Bays
- 2 (total) / 2 (free) x external - M.2 2230/2242/2260/2280/22110
- 2 x SATA 6Gb/s (replication) - 75 pin M.2 M-Key , USB 3.2 Gen 2 (1 rear) - 24 pin USB-C
- Supports AHCI mode, clone function, plastic housing, sector by sector duplication mode
- Cables Included
- 1 x USB-C to USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1 m
- MTBF
- 50,000 hours
- RoHS, WEEE
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- AC 100-240 V
- 0.1 Watt
- 7.7 cm
- 7.7 cm
- 4.4 cm
- 129 g
- Shipping Width
- 16 cm
- Shipping Depth
- 9 cm
- Shipping Height
- 9.5 cm
- Shipping Weight
- 500 g
- Limited warranty - 2 years
- 5 °C
- 55 °C
- 20 - 80% RH
StarTech.com M.2 NVMe SSD Enclosure for PCIe SSDs - USB 3.1 Gen 2 Type-C | In Stock | £44.81 |
StarTech.com USB PCIE/SATA M.2 Enclosure | In Stock | £43.99 |
