A spare drive tray for M2-REMOVABLE-PCIE-N1 or 2M2-REMOVABLE-PCIE, to add or swap a compatible drive. The drive tray accommodates M-Key M.2 NVMe SSDs in 2230, 2242, 2260, and 2280 sizes.
Toolless Installation
Install an M.2 drive into the drive tray without the need for tools. The drive tray features a power/activity LED indicator to monitor drive status. A latching mechanism with optional lock (2 keys included) deters the theft of mission-critical data storage devices. -
Optimal Performance
The tray features thermal pads which aid heat dissipation, ensuring optimal and reliable performance while reducing potential thermal throttling. Anti-vibration springs on the drive tray reduce impact during installation and enhance the overall stability and longevity of the drive. -
Hot-Swappable
When used with products from the PCIe Expansion Product Series, it provides flexibility and convenience for managing multiple M.2 drives. NVMe PCIe hot swap support is dependent on the motherboard. Verify hot swap support with the manufacturer of the motherboard and for instructions regarding how to enable this feature.
- StarTech.com M.2 NVMe SSD Drive Tray for use in PCIe Expansion Product Series - Drive Tray for an Additional Hot Swappable Drive (TR-M2-REMOVABLE-PCIE) - interface adapter - M.2 NVMe Card / PCIe 4.0 (NVMe) - PCIe 4.0
- Interface adapter - plug-in card
- Bus Type
- PCIe 4.0
- Black, silver
- Expansion Bays
- 1 x hot-swap - M.2 2230/2242/2260/2280
- Hard Drive Form Factor Compatibility
- M.2
- Interface
- Data Transfer Rate
- 64 Gbit/s
- Supported Devices
- Solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- 3.4 cm x 12.4 cm x 1.2 cm
- 36 g
- 2-year warranty
- M.2
- Host Bus
- PCIe 4.0
- Product Material
- Aluminium
- Black, silver
Storage Controller
- Interface
- 64 Gbit/s
- Supported Devices
- Solid state drive
- 1
- Bays
- 1 x M.2 Card - M.2 M key (internal)
- Connections
- 1 x PCIe 4.0
- Included Accessories
- 2 security keys, self-adhesive thermal pad
- Hot-swappable strorage bay, key lock, tool-less installation, LED indicator, anti-vibration springs, TRIM support, 4Kn drive compatible, S.M.A.R.T. support
- RoHS
- Limited warranty - 2 years
- 3.4 cm
- 12.4 cm
- 1.2 cm
- 36 g
- Shipping Width
- 14.5 cm
- Shipping Depth
- 7.5 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 79.2 g
- 0 °C
- 65 °C
- 0 - 90% RH
