StarTech.com M.2 NVMe Drive Tray
Quicklinx: HQ24WS00 Mfr#: TR-M2-REMOVABLE-PCIE
£27.24 ex VAT
£32.68 inc VAT
A spare drive tray for M2-REMOVABLE-PCIE-N1 or 2M2-REMOVABLE-PCIE, to add or swap a compatible drive. The drive tray accommodates M-Key M.2 NVMe SSDs in 2230, 2242, 2260, and 2280 sizes.
  • Toolless Installation
    Install an M.2 drive into the drive tray without the need for tools. The drive tray features a power/activity LED indicator to monitor drive status. A latching mechanism with optional lock (2 keys included) deters the theft of mission-critical data storage devices.
  • Optimal Performance
    The tray features thermal pads which aid heat dissipation, ensuring optimal and reliable performance while reducing potential thermal throttling. Anti-vibration springs on the drive tray reduce impact during installation and enhance the overall stability and longevity of the drive.
  • Hot-Swappable
    When used with products from the PCIe Expansion Product Series, it provides flexibility and convenience for managing multiple M.2 drives. NVMe PCIe hot swap support is dependent on the motherboard. Verify hot swap support with the manufacturer of the motherboard and for instructions regarding how to enable this feature.
StarTech.com M.2 NVMe SSD Drive Tray for use in PCIe Expansion Product Series - Drive Tray for an Additional Hot Swappable Drive (TR-M2-REMOVABLE-PCIE) - interface adapter - M.2 NVMe Card / PCIe 4.0 (NVMe) - PCIe 4.0
Interface adapter - plug-in card
Bus Type
PCIe 4.0
Black, silver
Expansion Bays
1 x hot-swap - M.2 2230/2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
64 Gbit/s
Supported Devices
Solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
3.4 cm x 12.4 cm x 1.2 cm
36 g
M.2
Host Bus
PCIe 4.0
Product Material
Aluminium
Black, silver
Storage Controller
Data Transfer Rate
64 Gbit/s
Supported Devices
Solid state drive
1
Bays
1 x M.2 Card - M.2 M key (internal)
1 x PCIe 4.0
2 security keys, self-adhesive thermal pad
Hot-swappable strorage bay, key lock, tool-less installation, LED indicator, anti-vibration springs, TRIM support, 4Kn drive compatible, S.M.A.R.T. support
RoHS
3.4 cm
12.4 cm
1.2 cm
36 g
Shipping Width
14.5 cm
Shipping Depth
7.5 cm
Shipping Height
2 cm
Shipping Weight
79.2 g
65 °C
0 - 90% RH
