StarTech.com M.2 NGFF to SATA Adapter
Quicklinx: B148WS00 Mfr#: SAT2M2NGFF25
Type: Storage controller
HD Size: M.2
Power Supply: [N/A]
£23.25 ex VAT
£27.90 inc VAT
Convert an m.2 NGFF solid state drive into a standard 2.5in form factor 6Gbps SSD. Vastly increase system performance by replacing your 2.5" SATA hard drive with an M.2 solid state drive, using the SAT2M2NGFF25 M.2 SSD to SATA adapter.
The M.2 to SATA adapter features an enclosed housing that adds protection to your NGFF (Next Generation Form Factor) SSD. The added protection gives you the peace of mind to confidently use your M.2 drive in applications that require an added level of durability such as hot-swap drive bays, or external SATA docking stations.
Using an M.2 SSD in place of a platter drive better utilizes the full potential of your SATA III controller, by reducing your data transfer bottleneck with file transfer speeds up to 6 Gbps - an ideal solution for further increasing the performance of a HyperDuo array.
For wide compatibility with all of the common M.2 solid state drives, the SAT2M2NGFF25 supports multiple drive heights including: 2242, 2260, 2280.
StarTech.com M.2 (NGFF) SSD to 2.5in SATA III Adapter - Up to 6 Gbps - M.2 SSD Converter to SATA with Protective Housing (SAT2M2NGFF25) - storage controller - SATA 6Gb/s - SATA
Storage controller - internal
Bus Type
SATA
Hard Drive Form Factor Compatibility
M.2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
Product Material
Aluminium / plastic
6.8 cm x 9.8 cm x 0.8 cm
50 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F
M.2
Host Bus
SATA
Product Material
Aluminium / plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1 x M.2 Card - M.2 Card
1 x SATA 6Gb/s - 22 pin Serial ATA
Screwdriver
Not compatible with M.2 NVMe or AHCI PCI-Express SSDs
Mounting Kit
Included
FCC, RoHS
6.8 cm
9.8 cm
0.8 cm
50 g
50 °C
5 - 95%
B148 StarTech.com 24" Serial ATA Cable In Stock £5.18
B148 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
B148 StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £6.44
B148 StarTech.com 18in SATA Serial ATA Cable In Stock £4.34
B148 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.16
B148 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.40
B148 StarTech.com 12in Latching SATA Cable In Stock £6.32
B148 StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit In Stock £4.38
B148 StarTech.com 12in SATA Serial ATA Cable In Stock £4.36
B148 StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M In Stock £5.67
B148 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.02
B148 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.34
B148 StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable In Stock £4.42
B148 StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £37.78
B148 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.83
B148 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.53
B148 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £19.62
B148 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £43.44
B148 StarTech.com M.2 NGFF to SATA Adapter In Stock £23.25
B148 StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £23.99
B148 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £56.93
B148 StarTech.com M.2 RAID Controller Card PCIe In Stock £65.07
B148 StarTech.com M.2 SATA Enclosure with USB-C In Stock £28.99
B148 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £23.56
B148 StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £21.56
B148 StarTech.com M.2 SATA Raspberry Pi Adapter In Stock £20.34
B148 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £35.34
B148 StarTech.com M.2 to U.2 Adapter In Stock £26.40
B148 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £152.39
B148 StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £28.73
B148 StarTech.com 18in Right Angle SATA Cable In Stock £4.24
HD Size: M.2
Power Supply: [N/A]
