StarTech.com LP PoweredUSB Adapter Card
Quicklinx: 76T7WS00 Mfr#: PEX312PUSBLP
This PCI Express based Powered USB Adapter Card adds three Powered USB (USB PlusPower) ports to any computer, through an available PCI Express Slot, and features a low profile design that is ideal for installations in a small form factor computer case. Drawing power from either the PCI Express slot or the computer power supply, the Powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at a time.Plus, this PCI Powered USB Adapter Card can be connected to StarTech.com's 2 Port 12V/24V Powered USB Adapter Card (PUSBADAP), to create two additional Powered USB ports, without using an extra PCI Express slot.
StarTech.com 3 Port LP PCI Express 12V PoweredUSB Adapter Card - USB PlusPower - USB adapter - PCIe - USB 2.0 x 3
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
USB 2.0 x 3
12 cm x 6.9 cm
200 g
USB, USB 2.0
Data Transfer Rate
480 Mbps
1 x NEC µPD720101GJ
Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
P/N: PUSBDYB24V06, PUSBDYB24V10, PUSBDYB24V03
USB adapter
PCI Express x1
Ports
USB 2.0 x 3
Wired
USB, USB 2.0
Data Transfer Rate
480 Mbps
Processor / Memory
1 x NEC µPD720101GJ
3 x USB 2.0 - 8 pin USB PlusPower (12 V)
Compatible Slots
1 x PCI Express x1 - low-profile
FCC, RoHS
Software Included
Drivers & Utilities
12 cm
6.9 cm
200 g
Limited warranty - lifetime
StarTech.com 24V to Hosiden+USB B Powered USB Cable
