Save space while improving the appearance of your working area with this low-profile TV wall mount. The mount sits close to the wall to support a VESA Mount compliant TV from 37" to 70", and offers anti-theft protection.
Low-Profile Design for Meeting Areas or Digital Signage
Mount your flat-screen TV or monitor in a location that's convenient for visitors, clients or employees. The wall mount safely and securely supports your TV in a fixed position, less than an inch (22 mm) from the wall, to provide a sleek, low-profile look. It's ideal for lobbies, hallways, boardrooms, works areas, customer-facing areas or for creating digital signage. The wall mount supports most 37" to 75" (940 to 1905mm) LED or LCD flat panel TVs weighing up to 88 lb. (40 kg). -
Anti-theft Protection
Engineered with heavy-duty steel, the robust steel TV wall mount securely supports your flat-screen TV, to protect your investment.Ideal for areas with high trafficand minimal supervision, the TV mount features a steel bar that can be locked into place with a padlock (purchased separately) to deter theft of your equipment.
- StarTech.com Low Profile TV Mount - Fixed - Anti Theft - Flat Screen TV Wall Mount for 37" to 75" TVs - VESA Wall Mount (FPWFXBAT) mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall plate, 2 mounting brackets, mounting bar, 2 decorative covers
- 98.5 cm x 2.2 cm x 44 cm
- 3.9 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-70"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 300 mm
- Max Load Weight
- 40 kg
- Material
- Plastic, steel
- Black
- Package Content
- 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 6 x concrete anchors, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws, 6 x screws, 6 x circular washers, 4 x rectangular washers
- 5-year warranty
- Designed For
- P/N: HDMIPLATE
- 98.5 cm
- 2.2 cm
- 44 cm
- 3.9 kg
- Material
- Plastic, steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 37"-70"
- Max Load Weight
- 40 kg
- Limited warranty - 5 years
- Designed For
- P/N: HDMIPLATE
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter | In Stock | £36.61 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.33 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.86 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £78.22 |
StarTech.com Full Motion TV Wall Mount | In Stock | £251.75 |
