Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com Low Profile TV Mount - Tilting
Quicklinx: CZCWWS00 Mfr#: FPWTLTBAT
Type: Mounting kit
£50.82 ex VAT
£60.98 inc VAT
Save space while improving the appearance of your working area with this low-profile TV wall mount. The mount sits close to the wall to support a VESA Mount compliant TV from 37" to 70", and offers anti-theft protection as well as titling capability that makes it easy to find the perfect viewing position.
  • Low-Profile Design for Meeting Areas or Digital Signage
    Mount your flat-screen TV or monitor in a location that's convenient for visitors, clients or employees. The wall mount safely and securely supports your TV about two inches (51 mm) from the wall to provide a sleek, low-profile look. It's ideal for lobbies, hallways, boardrooms, works areas, customer-facing areas or for creating digital signage. The wall mount supports most 37" to 75" (940 to 1905 mm) LED or LCD flat panel TVs weighing up to 88 lb. (40 kg).
  • Adjust Your Viewing Angle
    This TV wall mount tilts -10 to +5 degrees, so you can adjust the angle of your display with ease to customize your viewing experience.
StarTech.com Low Profile TV Wall Mount - Tilting - Anti Theft - Flat Screen TV Wall Mount for 37" to 75" TVs - VESA Wall Mount (FPWTLTBAT) mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
Wall plate, 2 bracket adapter, mounting bar, 2 decorative covers
98.5 cm x 5.1 cm x 44 cm
Tilt
-10° to 5°
Adjustments
Tilt
3.9 kg
Recommended Use
Flat panel
Recommended Display Size
37"-70"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
40 kg
Material
Plastic, steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 6 x concrete anchors, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws, 6 x screws, 6 x circular washers, 4 x rectangular washers
5-year warranty
P/N: HDMIPLATE
98.5 cm
5.1 cm
44 cm
3.9 kg
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
37"-70"
Tilt
-10° to 5°
Adjustments
Tilt
Max Load Weight
40 kg
Limited warranty - 5 years
P/N: HDMIPLATE
CZCW StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £32.94
CZCW StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.45
CZCW StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.75
CZCW StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
CZCW StarTech.com Full Motion TV Wall Mount In Stock £247.82
Type: Mounting kit
