This long range USB VGA KVM Console Extender lets you control a server, computer or multiple computers (connected through KVM Switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 1000ft away. You can use your existing USB keyboard, USB mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
The SV565UTPUL USB VGA Long Range KVM Console Extender is designed to provide long lasting, reliable operation.
- StarTech.com Long Range 1000 ft USB VGA KVM Over CAT5/5e CAT6 UTP Extender - KVM Console Over Ethernet for multiple servers/PC's IT Grade (SV565UTPUL) - KVM extender
- KVM extender
- Form Factor
- External
- Transmission Medium
- CAT 5/5e
- Max Transfer Distance
- 300 m
- 15.7 cm x 7 cm x 2 cm
- 1.5 kg
- 3-year warranty
- Designed For
- P/N: IM12D1500P, SV1631DUSBUK, SV831DUSBUK, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6
- KVM extender
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1200
- 300 m
- 1 x USB mouse , 1 x USB keyboard , 1 x VGA - HD-15 , 1 x KVM - HD-15
- Cables Included
- 1 x keyboard / mouse / video cable
- FCC, RoHS
- Power Device
- External power adapter
- 15.7 cm
- 7 cm
- 2 cm
- 1.5 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
|  | StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.44 |
|  | StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £288.51 |
|  | StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.65 |
|  | StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.71 |
|  | StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
|  | StarTech.com HDMI KVM Extender over LAN - 4K 30Hz | In Stock | £524.19 |
