StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft
Quicklinx: 76QHWS00 Mfr#: SV565UTPUL
Hurry, only 1 left in stock!
£304.11 ex VAT
£364.93 inc VAT
This long range USB VGA KVM Console Extender lets you control a server, computer or multiple computers (connected through KVM Switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 1000ft away. You can use your existing USB keyboard, USB mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
The SV565UTPUL USB VGA Long Range KVM Console Extender is designed to provide long lasting, reliable operation.
StarTech.com Long Range 1000 ft USB VGA KVM Over CAT5/5e CAT6 UTP Extender - KVM Console Over Ethernet for multiple servers/PC's IT Grade (SV565UTPUL) - KVM extender
KVM extender
External
Transmission Medium
CAT 5/5e
Max Transfer Distance
300 m
15.7 cm x 7 cm x 2 cm
1.5 kg
3-year warranty
P/N: IM12D1500P, SV1631DUSBUK, SV831DUSBUK, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6
KVM extender
External
Wired
Max Resolution
1920 x 1200
300 m
1 x USB mouse , 1 x USB keyboard , 1 x VGA - HD-15 , 1 x KVM - HD-15
1 x keyboard / mouse / video cable
FCC, RoHS
External power adapter
15.7 cm
7 cm
2 cm
1.5 kg
Limited warranty - 3 years
0 - 80%
76QH StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.85
76QH StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft In Stock £304.11
76QH StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.63
76QH StarTech.com HDMI KVM Extender over LAN - 4K 30Hz In Stock £543.93
