StarTech.com Lightning/Micro USB Cable
Quicklinx: BFP2WS00 Mfr#: LTUB1MWH
Colours:
Charge or sync your Micro USB, iPhone, iPod or iPad device using a single cable. Tired of carrying around multiple cables for charging and syncing your different mobile devices?
This convenient 2-in-1 cable lets you charge and sync either your Apple Lightning equipped devices or your Android mobile devices, through an available USB port on your PC or Mac computer.
Offering both a Lightning connector for your iPhone, iPod or iPad and a Micro USB connector for your Android phone or tablet, this is the perfect cable for all your mobile charging needs.
The LTUB1MWH white 2-in-1 charge-and-sync cable is Apple MFi certified.
StarTech.com 1m (3ft) Apple Lightning or Micro USB to USB Cable for iPhone / iPod / iPad - White - Apple MFi Certified (LTUB1MWH) - charging / data cable - Lightning / USB - 1 m
Cable
Charging / data cable - Lightning / USB
Shielded
American Wire Gauge (AWG)
24/28
Length
1 m
White
Connectors
USB - male
Connectors (Second End)
Micro-USB Type B - male , Lightning - male
P/N: HB30C4AFS
Cable Type
Interface Supported
Lightning / USB
Shielded
24/28
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
White
Connectors
4 pin USB Type A - male
5 pin Micro-USB Type B - male , Apple Lightning - male
MFI
P/N: HB30C4AFS
BFP2 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.79
BFP2 StarTech.com Lightning/Micro USB Cable In Stock £16.51
BFP2 StarTech.com 1m Lightning USB C Micro-B Cbl In Stock £24.01
