Do you carpool to work and need to flip a coin to see who will get to charge their tablet on the way to the office? Do you need to charge your tablet and phone at the same time, so that they're both ready to use by the time you reach your destination? Whatever your situation, this dual-port car charger offers a high-powered solution for charging two mobile devices simultaneously, while you're on the road.
Simultaneous Charging
Charge any Lightning mobile device, including your iPad or iPhone, using this convenient 2 port USB adapter. Reduce tangles and keep your vehicle tidy with the built-in coiled Lightning USB cable. Along with the Apple device, you can also charge USB-C or Micro-USB mobile devices, such as an Android smartphone, Samsung tablet, or GPS, using an appropriate cable (Lightning cable included. All other cables are sold separately). -
High-Powered Charging
Each charge port provides 2.1A of power to assure that you have enough power to charge everything from a phone to a tablet. Whether you're charging two tablets at the same time, or charging a phone and a tablet, you can be sure that all your mobile devices are ready when you needed. USBLT2PCARW2 is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance
- StarTech.com Lightning Car Charger with 1m Coiled Lightning Cable, 12W, White, 2 Port USB Car Charger Adapter for Phones and Tablets, In Car Apple iPhone/iPad Charger w/ Built-in Cord - Dual USB Car Charger (USBLT2PCARW2) car power adapter - USB, Lightning - 12 Watt
- Product Type
- Car power adapter
- 2.8 cm x 47.1 cm x 3.6 cm
- 6 g
- White
- Output Connector Type
- Total 2: USB, Lightning
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 V
- Max Electric Current
- 4.2 A
- Power Provided
- 12 Watt
- 2-year warranty
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone
- 2.8 cm
- 47.1 cm
- 3.6 cm
- 6 g
- Enclosure Colour
- White
- Voltage Required
- 12 - 24 V
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A, Apple Lightning
- Power Provided
- 12 Watt
- 4.2 A
- Built-in cable (1 m)
- Shipping Width
- 11 cm
- Shipping Depth
- 13 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 7.2 g
- Limited warranty - 2 years
