StarTech.com LC to LC Keystone Coupler
Quicklinx: HKKSWS00 Mfr#: DMFKSLCLCCOUPLER
Length: [N/A]
Colour: White
31 In Stock
£9.04 ex VAT
£10.84 inc VAT
Connect two LC Duplex fiber cables featuring UPC polished ends to extend a network connection, using this LC to LC Keystone Coupler. The female to female fiber coupler maintains optimal signal integrity while achieving low insertion loss that exceeds industry standards.
  • Compatible with Single Mode and Multimode Fiber Cables
    The LC Fiber Coupler supports Single Mode and Multimode LC/LC fiber cables. It is compatible with OS1/OS2 (9/125µm) and OM1/OM2/OM3/OM4/OM5 (62.5/125µm and 50/125µm) fiber core/cladding. The coupler fits securely into the keystone jack which can be installed in a keystone patch panel or wall plate without requiring additional tools.
  • Durable Construction
    The LC/LC Keystone Coupler features a durable ABS housing and ceramic-lined inner sleeves for precise fiber alignment, minimizing signal loss for long-lasting reliability and performance.
StarTech.com LC to LC Coupler, LC Fiber Coupler, LC/UPC Keystone Jack, Fiber Optic LC Keystone Coupler for Patch Panel - LC to LC Duplex (DMFKSLCLCCOUPLER) - network coupler - white
Network coupler - OM1/OM2/OM3/OM4/OM5/OS1/OS2
Duplex fibre optic
Keystone jack, passive adapter, ceramic sleeve, plastic housing
Core / Cladding Diameter
9 / 50 / 62.5 /125 micron
Connector
2 x LC single-mode / LC multi-mode - female
Connector (Second End)
White
Network Cable Type
Duplex fibre optic
Fibre Qty
2
1.9 cm
1.8 cm
2.2 cm
White
Connector
Plug and Play, TIA-568-B.3
-20 °C
60 °C
Length: [N/A]
Colour: White
