StarTech.com Laptop Stand for Desk
Quicklinx: GZ9CWS00 Mfr#: ADJ-LAPTOP-RISER
Device Type: Laptop
Type: Laptop Stand
Device Screen Size: [N/A]
Colour: Silver
24 In Stock
£72.84 ex VAT
£87.40 inc VAT
Adjust the height and tilt of a laptop to eye level for ergonomic comfort and increased productivity. The laptop riser stand supports any laptop with a maximum weight capacity of 22lb (10kg). The lightweight and foldable design enables quick transportation and convenient storage. When collapsed, the riser measures 10.6x8.8x1.9in (27x22.5x5cm). The laptop riser for desks ships fully assembled for immediate use.
  • Tilt for Ideal Viewing
    This ergonomic laptop stand features tilt and height adjustments (up to 4.7in/12cm) to establish the most comfortable viewing angle. Adjust the tension of the support arms, using the included tool, for various weight, tilt, and height settings. The raised flanges (0.7in /18mm), located at the front of the laptop platform, ensure the laptop remains in place when the platform is tilted. Rubber pads around the surface help protect the laptop from cosmetic damage.
  • Stable Laptop Stand
    The laptop riser features a silver anodized finish with aluminum construction to ensure durability and sturdiness. The vented surface area is elevated to promote passive cooling and airflow. The space underneath the laptop platform can be used to store a keyboard, mouse, and/or other accessories and peripherals when they are not in use. The non-skid rubber feet aid in protecting the surface of the desk from scratches and scuffs, including glass top desks. This product is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Laptop Stand for Desk, Ergonomic Laptop Stand Adjustable Height, Aluminum, Portable, Supports up to 22lb (10kg), Foldable Laptop Holder for Desk - Angled Notebook Computer Riser/Lift (ADJ-LAPTOP-RISER) - notebook stand
Notebook stand
Placing / Mounting
Desk mountable
Package Content
Notebook riser
Silver
Product Material
Aluminium
22.6 cm x 26.9 cm x 5 cm
700 g
Ergonomic
5-year warranty
P/N: PRIVSCNLT15, PRIVSCNMAC13, PRIVSCNMAC15
Notebook stand
Placing / Mounting
Desk mountable
Product Material
Aluminium
Package Content
Notebook riser
22.6 cm
26.9 cm
5 cm
Max Load Weight
10 kg
700 g
23.5 cm x 28 cm x 6 cm / 0.9 kg
Silver
Ergonomic
Limited warranty: - 5 years
GZ9C StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £38.92
GZ9C StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £35.69
GZ9C StarTech.com 15in Laptop Privacy Screen - Magnetic - 16:10 Aspect Ratio In Stock £53.24
Device Type: Laptop
Type: Laptop Stand
Colour: Silver
