StarTech.com Laptop Stand for Desk 5kg/11lb
Quicklinx: GTBLWS00 Mfr#: LAPTOP-STAND-SILVER
Device Type: Laptop, Notebook
Type: Laptop Stand
Device Screen Size: 13 - 17
Colour: Silver
36 In Stock
£35.51 ex VAT
£42.61 inc VAT
Raise your laptop on your desk for more comfortable viewing while saving desktop space and increasing your comfort and productivity. The laptop riser supports most laptops including 13", 15.6", and 17" with a maximum weight of 11 lbs (5 kg). The lightweight design (2.13 lbs / 970 g) allows you to reorganize your workspace with ease. Overall dimensions 10.2x8.7x5.6 in (260x223x144 mm).
  • Stable Laptop Stand
    The elegant laptop riser features a silver anodized finish with 0.19in (5mm) thick aluminum parts to ensure its durability. The two support arms create an effective surface area of 8.26x10.23 in (210x260 mm) and provide generous room underneath for passive cooling and airflow, and can be used to store a keyboard, mouse, or other accessories and peripherals when they are not in use.
  • Simple Assembly
    The laptop stand for desks is easily put together with only 3 components that can be assembled by hand. Cable management openings at the back of the support arms help to keep your cables tidy and organized. The non-skid rubber feet protect your work surface from scratches and scuffs.
  • Tilted for Ideal Viewing
    The ergonomic laptop stand is tilted slightly downward at 16 degrees providing a comfortable viewing angle. The raised lip on the front of the support arms with the help of the rubber pads on the surface prevents the laptop from sliding off. LAPTOP-STAND SILVER is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Laptop Stand for Desk, 5kg/11lb, Aluminum, Silver, Ergonomic - notebook stand
Notebook stand
Package Content
2 support arms, crossbar
Silver
Product Material
Aluminium
22.3 cm x 26 cm x 14.4 cm
1 kg
Notebook Supported Sizes
13" - 17" / 33 cm - 43.2 cm
Non-slip rubber pads, portable, ergonomic, 16° angled, fixed front height up to 10.6cm
5-year warranty
Notebook stand
Product Material
Aluminium
Package Content
22.3 cm
26 cm
14.4 cm
1 kg
20 cm x 32.5 cm x 6 cm / 1 kg
Silver
Finish
Anodised
Weight Limit
5 kg
Limited warranty: - 5 years
GTBL StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio In Stock £31.60
GTBL StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio In Stock £32.64
GTBL StarTech.com Laptop Stand for Desk In Stock £63.96
Device Type: Laptop
Device Type: Notebook
Type: Laptop Stand
Colour: Silver
