The Nano Slot Compatible 6.6ft (2m) Cable Lock from StarTech.com offers a robust solution for laptop security. This cable lock features anti-theft protection, ensuring that valuable devices are safeguarded against unauthorized access. With a combination lock method and a Kensington Nano Slot design, it provides peace of mind for users seeking to secure their laptops effectively.
This cable lock is cut-resistant and boasts 360° rotation, allowing for versatile positioning without compromising its security features. Made from high-quality materials, the package includes a hook-and-loop strap for easy storage and organization. Ideal for notebook users, this cable lock emphasizes safety and convenient features, making it a practical accessory for any tech-savvy individual.
Reliable anti-theft protection
Designed to deter theft, this cable lock provides dependable anti-theft protection for laptops, ensuring devices remain secure. -
Durable cut-resistant material
Constructed from robust materials, the cut-resistant design enhances the lock's durability and helps prevent tampering. -
Versatile 360° rotation
The 360° rotation feature allows the cable to be positioned conveniently, accommodating various setups without sacrificing security. -
Compatible Kensington Nano Slot
The lock is specifically engineered for Kensington Nano Slot compatibility, making it a fitting choice for compatible devices. -
User-friendly combination lock
Featuring a combination lock method, it provides an added layer of security while making it easier for users to access their devices.
- StarTech.com Nano Slot Compatible 6.6ft (2m) Cable Lock, Laptop Security - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-Loop fastening strap
- Black & silver
- Product Material
- Steel, plastic
- 15 cm 2.2 cm
- Length
- 2 m
- 105 g
- 360° rotation, anti-theft protection, cut-resistant, Kensington Nano Slot
- 2-year warranty
- Product Type
- Product Material
- Steel, plastic
- Package Content
- 15 cm
- 2.2 cm
- Length
- 2 m
- 105 g
- Shipping Dimensions (WxDxH) / Weight
- 2 cm x 5.4 cm x 1.6 cm
- Black & silver
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- Nano
- Lock Method
- Combination
- Limited warranty: - 2 years
- -20 °C
- 40 °C
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £10.22 |
StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable | In Stock | £6.34 |
StarTech.com Rotating Laptop Stand/Riser | In Stock | £51.40 |
