StarTech.com Laptop Nano Cable Lock, 5ft
Quicklinx: J1KCWS00 Mfr#: SNANOC4D-LAPTOP-LOCK
24 In Stock
£16.40 ex VAT
£19.68 inc VAT
The Nano Slot Compatible 6.6ft (2m) Cable Lock from StarTech.com offers a robust solution for laptop security. This cable lock features anti-theft protection, ensuring that valuable devices are safeguarded against unauthorized access. With a combination lock method and a Kensington Nano Slot design, it provides peace of mind for users seeking to secure their laptops effectively.
This cable lock is cut-resistant and boasts 360° rotation, allowing for versatile positioning without compromising its security features. Made from high-quality materials, the package includes a hook-and-loop strap for easy storage and organization. Ideal for notebook users, this cable lock emphasizes safety and convenient features, making it a practical accessory for any tech-savvy individual.
  • Reliable anti-theft protection
    Designed to deter theft, this cable lock provides dependable anti-theft protection for laptops, ensuring devices remain secure.
  • Durable cut-resistant material
    Constructed from robust materials, the cut-resistant design enhances the lock's durability and helps prevent tampering.
  • Versatile 360° rotation
    The 360° rotation feature allows the cable to be positioned conveniently, accommodating various setups without sacrificing security.
  • Compatible Kensington Nano Slot
    The lock is specifically engineered for Kensington Nano Slot compatibility, making it a fitting choice for compatible devices.
  • User-friendly combination lock
    Featuring a combination lock method, it provides an added layer of security while making it easier for users to access their devices.
StarTech.com Nano Slot Compatible 6.6ft (2m) Cable Lock, Laptop Security - security cable lock
Security cable lock
Package Content
Hook-and-Loop fastening strap
Black & silver
Product Material
Steel, plastic
15 cm 2.2 cm
Length
2 m
105 g
360° rotation, anti-theft protection, cut-resistant, Kensington Nano Slot
Security cable lock
Product Material
Steel, plastic
Package Content
15 cm
2.2 cm
Length
2 m
105 g
2 cm x 5.4 cm x 1.6 cm
Black & silver
Security Cable Lock
Intended For
Notebook
Lock Type
Nano
Lock Method
Combination
Limited warranty: - 2 years
-20 °C
J1KC StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor In Stock £10.22
J1KC StarTech.com Laptop Cable Lock Anchor - Large In Stock £11.18
J1KC StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable In Stock £6.34
J1KC StarTech.com Rotating Laptop Stand/Riser In Stock £51.40
