Boardroom Docking Station 4K HDMI USB-C and USB-A USB-C Power Delivery. Add docking and video conferencing capabilities to a boardroom, classroom or huddle space. This laptop docking module for the StarTech.com conference table connectivity box lets you:
One connection to access your room's display and collaboration peripherals
Charge mobile devices using the USB-A charge port
Power a supported USB-C laptop with USB Power Delivery
Dock Your Laptop
Modern office environments need to support technology more than ever, to keep laptops, phones and tablets connected. During meetings, you may need to set up video conference calls using applications such as Microsoft Teams, Zoom or Google Hangouts. Unlike other boardroom conferencing solutions that are limited to only one or two collaboration applications, this module lets you use your own laptop, so you are not restricted to a specific platform.
Connect a USB-C or USB-A laptop to the module and access your room's peripherals, webcams, speakers, mics, network and HDMI display. This docking station module lets you easily connect your laptop with each video conferencing device in your boardroom. You can collaborate with others in the room and around the globe.
For users that are unable to dock or for quick access to the display, the front-facing HDMI port lets you connect a laptop directly to the display.
Customizable
Architectural connectivity is becoming the trend when designing a boardroom or huddle space. StarTech.com docking station modules let you:
Customize according to the specific needs of your small, medium or large size room
Install in easy-to-access locations
Easily integrates with existing and new collaboration hardware
You can install this module as a standalone solution using the supplied table-mounting bracket, or as an addition to a StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference room table connectivity box (each sold separately).
MOD4DOCKACPD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Dock Your Laptop
Modern office environments?need to support technology more than ever, to keep laptops, phones and tablets connected.?During?meetings, you may need?to set up video conference calls using applications such as Microsoft Teams, Zoom or Google Hangouts. Unlike other boardroom conferencing solutions that are limited to only one or two collaboration applications, this module lets you use your own laptop, so you are not restricted to a specific platform. Connect a USB-C or USB-A laptop to the module and access your room's peripherals, webcams, speakers, mics, network and HDMI display. This docking station module lets you easily connect your laptop with each video conferencing device in your boardroom. You can collaborate with others in the room and around the globe. For users that are unable to dock or for quick access to the display, the front-facing HDMI port lets you connect a laptop directly to the display. -
Customizable
Architectural connectivity is becoming the trend when designing a boardroom or huddle space.?StarTech.com docking station modules let you:? • Customize?according to the specific needs of your small, medium or large size room? • Install?in easy-to-access locations? • Easily integrates with existing and new collaboration hardware You can install this?module?as?a?standalone solution?using the supplied table-mounting bracket, or as an addition to a StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference room table connectivity box (each sold separately). -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com Laptop Docking Module for Conference Table Connectivity Box - 4K HDMI - USB-C / USB-A - USB-C PD - Boardroom Docking Station (MOD4DOCKACPD) - docking station - USB-C - HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI
- 10.7 cm x 8.5 cm x 6 cm
- 649 g
- Black
- Networking
- Gigabit Ethernet
- 2-year warranty
- Designed For
- P/N: BEZ4MOD, BOX4MODULE
- Product Type
- Docking station
- 10.7 cm
- 8.5 cm
- 6 cm
- 649 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 3840 x 2160 - 30 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, Power Delivery 2.0
- 3 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x microphone - mini-phone 3.5 mm , 1 x speakers - mini-phone 3.5 mm , 1 x network - RJ-45 , 1 x SuperSpeed USB 3.0 - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB-C cable , 1 x USB-A to USB-B cable
- Included Accessories
- Mounting bracket, screws
- 4K Ultra HD, 60W power delivery
- USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol)
- OS Required
- Apple MacOS X 10.9 - 10.12, Google Chrome OS 55 or later, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 2 years
- Shipping Weight
- 2.4 kg
- 0 °C
- 40 °C
- Designed For
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.23 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.14 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £17.97 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £16.00 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.46 |
StarTech.com 5m 15ft Premium 4K HDMI Cable | In Stock | £24.69 |
StarTech.com 7m 23ft Premium 4K HDMI Cable | In Stock | £36.43 |
StarTech.com 0.5m Premium 4K HDMI Cable | In Stock | £9.95 |
StarTech.com Laptop Docking Module Conference Table Connectivity Box 4K
