StarTech.com Laptop Desk Mount. VESA Tray
Quicklinx: H137WS00 Mfr#: A-LAPTOP-DESK-MOUNT
Device Type: Laptop, Monitor
Type: Mounting kit
Device Screen Size: 13 - 34
Colour: Black
£66.55 ex VAT
£79.86 inc VAT
Increase your desk space and add versatility and ergonomics to your work/home setup with this laptop desk mount. The tray (11.8 x 11 in / 300 x 280 mm) is large enough to hold a laptop between 9.4 - 16.5 inches (240 - 420 mm) wide, 1 inch (25.4 mm) thick, and of up to 10 lbs (4.5 kg).
  • Ergonomic and adaptable
    The arm offers a high number of adjustments such as tilt +45/-45° tilt, swivel +90/-90°; rotation 360°; and height adjustment along the (17.7 in / 449 mm) pole. The arms can extend a maximum of 16.85 inches / 423 mm from the pole. The mechanical height adjustment provides a sturdy laptop tray to reduce bounce when typing. The multiple adjustment options allow the laptop to be positioned at eye level improving posture, comfort, and to be aligned with any existing monitors improving productivity.
  • Ventilated Laptop Tray
    The laptop tray is well ventilated and includes optional rubber pads to prevent scuffs and scratches. In addition, the laptop tray features two independent adjustable padded arms that serve as a cradle to secure the laptop and can be independently positioned and secured along the sides of the tray to prevent blocking any port configuration on a laptop.
  • Mounting options
    Using the interchangeable desk clamp (c-clamp) you can easily attach and secure the mount to a desk or grommet hole (0.39in - 3.46in / 10mm - 88mm thick) by hand. You can optionally remove the laptop tray and use the arm to mount a VESA compatible 75x75mm or 100x100mm 27" display or 34" (21:9) ultrawide display with a maximum weight of 17.6 lbs (8 kg). A-LAPTOP-DESK-MOUNT is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Laptop Desk Mount, Monitor and Laptop Mount for Desk, Displays 34in (8kg/17.6lb) & Laptops (4.5kg/9.9lbs), Adjustable & Articulating VESA Laptop Tray Arm - Desk Monitor Mount - Clamp / Grommet Mount (A-LAPTOP-DESK-MOUNT) mounting kit - for monitor / notebook - black
Mounting kit - notebook mount
Mounting Components
Tray, articulating arm, desk clamp mount, pole
70.8 cm x 42 cm x 55 cm
Tilt
-45° to 45°
Rotation
360°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
5.1 kg
Recommended Use
Monitor / notebook
Recommended Display Size
13"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, steel
Package Content
Cable-management clip (pole), 4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (5mm), 5 x rubber pads, hex key (6mm), grommet base plate, 1 x pole screw, 2 x notebook arms, 2 x notebook arm clips, 4 x tray mounting screws, 1 x grommet clamp plate
5-year warranty
70.8 cm
42 cm
55 cm
5.1 kg
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor / notebook
Placing / Mounting
Notebook mount
Cable Management
Integrated cable management
13"-34"
Tilt
-45° to 45°
Rotation
360°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
Dimensions
Tray - width: 30 cm height: 28 cm
47 cm x 30.3 cm x 17.3 cm / 5.1 kg
Limited warranty - 5 years
H137 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.28
H137 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
H137 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
Device Type: Laptop
Device Type: Monitor
Type: Mounting kit
Colour: Black
