StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable
Quicklinx: FLXCWS00 Mfr#: BRNCHLOCK
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black, Silver
26 In Stock
£7.12 ex VAT
£8.54 inc VAT
Here's an easy and economical way to secure accessories to your main lock cable. This laptop cable lock expansion loop works with your base laptop lock, to add a 6" (2.5 cm) extension cable and lock-head that connects into devices with the Kensington K-Slot.
The expansion loop with a K-slot lock head makes an ideal accessory to loop around any type of main cable lock - including a K-slot, nano or Noble Wedgelock letting you easily secure a variety of devices.
Now if you have a single laptop lock, you can protect more devices like your docking station or monitor. This lock accessory works like a dual-head or twin laptop lock to secure additional devices with ease.
You can even use multiple laptop lock expansion loops to protect devices on your desk, or on display, while taking up little space. It's the ideal way to help prevent theft and tampering in areas with high foot traffic including retail, commercial, educational and institutional environments.
Choose your own combination so you can remember it easily. Or, change your passcode often to prevent others from knowing it.
To ensure that your dock, tablet or other device is anchored safely, the computer security cable features a vinyl-coated steel cable (4.4 mm diameter). The laptop lock add-on features a durable zinc-alloy lock head, to provide dependable theft protection.
  • Robust Design
    Crafted from zinc alloy, this security cable lock is built to withstand physical attempts to breach its integrity, ensuring that devices remain secure in various settings.
  • Standards Compliance
    The lock is compliant with RoHS and REACH regulations, reflecting a commitment to safe and environmentally responsible materials, making it suitable for use in sensitive settings.
StarTech.com Universal Laptop Cable Lock Expansion Loop, 6” (15cm) Anti Theft 4-Digit Combination K-Slot Lock, Computer Security Cable to Create Twin/Multi-Head Lock for Multiple Devices - Security Cable Loop (BRNCHLOCK) - security cable lock
Security cable lock
Black & silver
Product Material
Zinc alloy
4.81 cm 1.6 cm
Length
15 cm
67 g
Security cable lock
Product Material
Zinc alloy
4.81 cm
1.6 cm
Length
15 cm
67 g
17 cm x 14.2 cm x 3 cm / 68 g
Black & silver
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
Device Type: Laptop
Type: Security
Colour: Black
Colour: Silver
