Create a versatile and secure anchor point in almost any location, to help guard your laptop, docking station or other device against theft. This laptop cable-lock anchor features a large ringed design that attaches easily to a solid surface, to provide a strong and secure anchor point for your cable lock (sold separately).
With its large ringed design, the cable lock anchor point provides ample room to thread thicker cable locks, or more than one cable through the 1.4" W x 0.7" H (35 x 19 mm) opening.
Protect your device, and your investment, by adding a laptop cable-lock anchor point to a desk, counter, cabinet, wall or other solid location. The screw-on cable lock anchor makes it easy to lock your laptop to your desk. It features a small footprint and is easy to attach using two screws and the adhesive pad (included). It gives you the convenience of choosing the location of the anchor point for your cable lock.
Made of durable zinc alloy, the ringed deskmount security anchor point can withstand a strong force from the cable lock in all directions. The robust construction of the computer security cable anchor helps to prevent the anchor point from being tampered with or cut. The security plate prevents access to the mounting screws.
Strong construction
Made from high-quality steel, this lock anchor offers strength and durability for long-lasting use. -
Complete installation kit
The package comes with a cover plate, two wood screws, an abrasive pad, and an alcohol wipe for simple mounting.
- StarTech.com Laptop Cable Lock Anchor - Large - Security Cable Anchor Point - lock anchor
- Product Type
- Lock anchor
- Package Content
- Cover plate, 2 wood screws, abrasive pad, alcohol wipe
- Silver
- Product Material
- Steel
- 6.7 cm x 4.7 cm x 3.1 cm
- 100 g
- 2-year warranty
- Designed For
- P/N: LTLOCKNBL
- Product Type
- Lock anchor
- Product Material
- Steel
- Package Content
- 6.7 cm
- 4.7 cm
- 3.1 cm
- 100 g
- Shipping Dimensions (WxDxH) / Weight
- 12 cm x 2 cm x 8.5 cm / 101 g
- Silver
- Limited warranty: - 2 years
- Designed For
- P/N: LTLOCKNBL
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £10.20 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £27.09 |
StarTech.com Universal Laptop Lock, 3-in-1 | In Stock | £29.61 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £552.36 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £577.21 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £612.06 |
StarTech.com 3-in-1 Universal Laptop Lock | In Stock | £26.84 |
StarTech.com Universal Laptop Cable Lock | In Stock | £24.65 |
