StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor
Quicklinx: F3B9WS00 Mfr#: LTANCHOR
Device Type: Laptop, Other
Type: Security
Device Screen Size: [N/A]
Colour: Silver
More than 50 In Stock
£10.22 ex VAT
£12.26 inc VAT
Now you can help to guard your laptop, docking station or other device against theft. This laptop cable lock anchor attaches easily to a solid surface, to provide a strong and secure anchor point for your cable lock (sold separately).
Protect your device, and your investment, by adding a secure lock anchor point to a desk, counter, cabinet, wall or other solid location. The computer security-cable anchor features a small footprint and is easy to attach using two screws and the adhesive pad(included). It gives you the convenience of choosing the location of the anchor point for your cable lock.
Made of stainless steel, the ringed desk mount cable anchor can withstand a strong force from the cable lock in all directions. The robust steel construction helps to prevent the anchor point from being tampered with or cut. The steel security plate prevents access to the mounting screws.
  • Robust construction
    Made from steel, this lock anchor ensures strength and durability, providing reliable protection for your devices.
  • Convenient installation
    The screw-on design allows for easy installation on various surfaces, making it versatile for different setups.
StarTech.com Laptop Cable Lock Anchor - Zinc Alloy - Computer Security Cable Anchor - Desk Mount Security Anchor Point - Screw-On Lock Anchor (LTANCHOR) - lock anchor
Lock anchor
Package Content
Cleaning wipe, pad, 2 wood screws
Silver
Product Material
Steel
4.4 cm x 4.58 cm x 2.79 cm
61 g
P/N: LTLOCKNBL
Lock anchor
Product Material
Steel
Package Content
4.4 cm
4.58 cm
2.79 cm
61 g
Silver
Limited warranty: - 2 years
P/N: LTLOCKNBL
Device Type: Laptop
Device Type: Other
Type: Security
Colour: Silver
