StarTech.com Laptop Cable Lock 6Ft
Quicklinx: HDG0WS00 Mfr#: NBLWK-LAPTOP-LOCK
Device Type: Laptop
Type: Security Kit
Device Screen Size: [N/A]
Colour: Black/Silver
13 In Stock
£25.48 ex VAT
£30.57 inc VAT
Laptop Cable Lock is compatible with Noble Wedge slot, and it's designed to deter the theft of laptops and other ultra-slim notebooks. The laptop lock features a 6.5ft (2m) cut-resistant cable with a PVC coating, making it a durable and reliable solution for securing laptops. The lock body features zinc-alloy plating, which prevents corrosion and wear. The compact design of this lock is perfect for ultra-slim notebooks, 2-in-1 laptops, tablets, and many other devices that feature a Noble Wedge slot.
  • Full-Motion Lock Design
    The diameter of the lock body is 0.4in (11.6mm), with an off-center lock tip that enables a slim laptop (e.g., Ultrabook) to lay flat when the lock is attached. Additionally, the lock head features both pivot and ball joints, allowing the lock to pivot 90° and rotate a full 360°.
  • Flexible Installation
    The 6.5ft, 4.4mm cut-resistant steel cable can be routed through a grommet hole or wrapped around to the leg of a table. It is the ideal security lock for tradeshow/kiosk product exhibits, POS device protection, and office device security. Enhance the convenience and security of this product, using LTANCHOR or LTANCHORL (sold separately), to secure a device to a table or desk. The multitude of installation options ensures this lock will fit any application. The lock head features a spacer near the lock tip that protects the device from scuffing or denting the laptop's lock slot. The lock includes a set of two zinc alloy keys.
StarTech.com Laptop cable lock 6Ft Compatible With Noble Wedge; Laptop Cable Lock, 6Ft (2m), Anti-Theft Keyed Lock, Security Cable Lock For Dell XPS/Latitude, Cut-Resistant Steel Cable Lock For Laptop (NBLWK-LAPTOP-LOCK) - security cable lock
Security cable lock
Package Content
Hook-and-Loop fastening strap, 2 x keys
Black, silver
1.2 cm 2.1 cm
Length
2 m
Theft protection
Security cable lock
Package Content
1.2 cm
2.1 cm
Length
2 m
20.5 cm x 12.8 cm x 1 cm / 180 g
Black, silver
Theft protection
Limited warranty: - 2 years
HDG0 StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor In Stock £10.45
HDG0 StarTech.com Laptop Cable Lock Anchor - Large In Stock £11.84
HDG0 StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable In Stock £6.66
Device Type: Laptop
Type: Security Kit
