Laptop Cable Lock is compatible with Noble Wedge slot, and it's designed to deter the theft of laptops and other ultra-slim notebooks. The laptop lock features a 6.5ft (2m) cut-resistant cable with a PVC coating, making it a durable and reliable solution for securing laptops. The lock body features zinc-alloy plating, which prevents corrosion and wear. The compact design of this lock is perfect for ultra-slim notebooks, 2-in-1 laptops, tablets, and many other devices that feature a Noble Wedge slot.
Full-Motion Lock Design
The diameter of the lock body is 0.4in (11.6mm), with an off-center lock tip that enables a slim laptop (e.g., Ultrabook) to lay flat when the lock is attached. Additionally, the lock head features both pivot and ball joints, allowing the lock to pivot 90° and rotate a full 360°. -
Flexible Installation
The 6.5ft, 4.4mm cut-resistant steel cable can be routed through a grommet hole or wrapped around to the leg of a table. It is the ideal security lock for tradeshow/kiosk product exhibits, POS device protection, and office device security. Enhance the convenience and security of this product, using LTANCHOR or LTANCHORL (sold separately), to secure a device to a table or desk. The multitude of installation options ensures this lock will fit any application. The lock head features a spacer near the lock tip that protects the device from scuffing or denting the laptop's lock slot. The lock includes a set of two zinc alloy keys.
- StarTech.com Laptop cable lock 6Ft Compatible With Noble Wedge; Laptop Cable Lock, 6Ft (2m), Anti-Theft Keyed Lock, Security Cable Lock For Dell XPS/Latitude, Cut-Resistant Steel Cable Lock For Laptop (NBLWK-LAPTOP-LOCK) - security cable lock
- Product Type
- Security cable lock
- Package Content
- Hook-and-Loop fastening strap, 2 x keys
- Black, silver
- 1.2 cm 2.1 cm
- Length
- 2 m
- Theft protection
- 2-year warranty
- Product Type
- Package Content
- 1.2 cm
- 2.1 cm
- Length
- 2 m
- Shipping Dimensions (WxDxH) / Weight
- 20.5 cm x 12.8 cm x 1 cm / 180 g
- Black, silver
- Theft protection
- Limited warranty: - 2 years
- 0 °C
- 40 °C
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £10.88 |
StarTech.com Laptop Cable Lock Anchor - Large | In Stock | £14.26 |
StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable | In Stock | £7.46 |
