StarTech.com Laptop Cable Lock, Swivel Hinge - 4-Digit Combination Lock
Quicklinx: F3BCWS00 Mfr#: LTLOCK4D
Device Type: Tablet
Type: Security
Device Screen Size: [N/A]
Colour: Black/Silver
More than 50 In Stock
£16.06 ex VAT
£19.27 inc VAT
Protect your laptop, dock or other device against theft while enhancing productivity with this laptop cable lock, providing a full range of motion. The laptop anti-theft lock has a 4-digit resettable combination for enhanced security at the office or on the go.
While your laptop, dock or other device is secured with the locking cable, you can move your device freely. The swivel hinge allows motion in two directions - the hinge rotates 360 degrees around the lock head, and pivots 90 degrees for easy locking and unlocking.
Choose your own combination so you can remember it easily. Or, prevent others from knowing your passcode by changing it often. The 4-digit combination security cable lock is easy to change.
Ensure that your laptop or other device is protected wherever you work. The 2 m(6.5') locking cable helps to prevent theft in areas with high foot traffic including a wide range of retail, commercial, educational and institutional environments. The cable lock is compatible with devices equipped with the industry-standard Kensington lock slot (K-Slot).
Ideal for use at the office or when travelling, the portable combination laptop lock features a strong vinyl-coated steel cable (4.4 mm diameter). To secure your device in different work spaces, the flexible steel cable bends easily to loop around a stationery post or object.
StarTech.com 6.5ft (2m) Laptop Cable Lock, 4 Digit Combination Laptop/Desktop Security Cable Lock for K-Slot Devices/Computers/Monitors, Portable Anti-Theft Vinyl Coated Steel Cable Lock - K Slot Laptop Lock (LTLOCK4D) - security cable lock
Security cable lock
Product Material
Vinyl-coated steel
5.51 cm x 2 m x 1.6 cm
Length
2 m
128 g
Combination lock, 4 digit code, anti-theft protection, kensington security slot, swivel hinge
Security cable lock
Product Material
Vinyl-coated steel
5.51 cm
2 m
1.6 cm
Length
2 m
128 g
Limited warranty: - 2 years
F3BC StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination In Stock £17.93
F3BC StarTech.com Keyed Cable Lock - Push-to-Lock Button - 2 m / 6.5’ Cable In Stock £19.06
F3BC StarTech.com Laptop Cable Lock Expansion Loop - 6" / 2.5 cm Branch Cable In Stock £6.65
F3BC StarTech.com Laptop Cable Lock - 4-Digit Resettable Combination Lock - For Wedge Lock Slot In Stock £24.11
Device Type: Tablet
Type: Security
